System Administration Guide: Advanced Administration
Selecting the Destination (or Network Printer Access) Name
The print subsystem requires access information for the printer. The subsystem uses the destination name when making the network connection to the printer. This name is supplied by the system administrator to the print subsystem by using the lpadmin command. It becomes part of the printer configuration database. The printer access name is the name of the printer node, sometimes qualified by a port name. Port designation varies across printer vendors. You will find information about port designation in the documentation that is provided with the printer by the printer vendor. The format of printer access name is:
printer_node-name[:port-designation]
Example 1—Destination (or Network Printer Access Name) With Port Designation (Number)
A common port designation with TCP is 9100. If the printer node name is pn1, and the printer vendor defines the port as 9100, then the printer access name is: pn1:9100. To configure a printer in this case use:
# lpadmin -p printer_name -o dest=pn1:9100
Example 2—Destination (or Network Printer Access Name) With Port Designation (Name)
When using the BSD protocol, the port designation might not be a number, but some name defined by the printer vendor, for example: xxx_parallel_1. If the printer node name is cardboard, then the printer access name is: cardboard:xxx_parallel_1. To configure a printer in this case use:
# lpadmin -p printer-name -o dest=cardboard:xxx_parallel_1
Example 3—Destination (or Network Printer Access Name) With No Port Designation
If there is no port designation, and the printer node name is newspaper, the printer access name is the printer node name: newspaper. To configure a printer in this case use:
# lpadmin -p printer_name -o dest=newspaper
