Use the sar -v command to report the status of the process table, inode table, file table, and shared memory record table.
$ sar -v 00:00:00 proc-sz ov inod-sz ov file-sz ov lock-sz 01:00:00 43/922 0 2984/4236 0 322/322 0 0/0 |
Output from the -v option is described in the following table.
Table 24–18 Output From the sar -v Command
Field Name |
Description |
proc-sz |
The number of process entries (proc structures) that are currently being used, or allocated in the kernel. |
inod-sz |
The total number of inodes in memory versus the maximum number of inodes that are allocated in the kernel. This number is not a strict high water mark. The number can overflow. |
file-sz |
The size of the open system file table. The sz is given as 0, since space is allocated dynamically for the file table. |
ov |
The number of shared memory record table entries that are currently being used or allocated in the kernel. The sz is given as 0 because space is allocated dynamically for the shared memory record table. |
lock-sz |
The following abbreviated example shows output from the sar -v command. This example shows that all tables are large enough to have no overflows. These tables are all dynamically allocated based on the amount of physical memory.
$ sar -v SunOS touchstone 5.9 Generic sun4u 03/04/2003 00:00:00 proc-sz ov inod-sz ov file-sz ov lock-sz 01:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 02:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 03:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 04:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 05:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 06:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 07:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 08:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 08:20:01 64/1898 0 4280/8467 0 0/0 0 0/0 08:40:00 64/1898 0 4280/8467 0 0/0 0 0/0 09:00:00 64/1898 0 4280/8467 0 0/0 0 0/0 09:20:01 70/1898 0 4281/8467 0 0/0 0 0/0 09:40:01 70/1898 0 4281/8467 0 0/0 0 0/0 10:00:02 71/1898 0 4285/8467 0 0/0 0 0/0 |
