Use the iostat command to report statistics about disk input and output, and produces measures of throughput, utilization, queue lengths, transaction rates, and service time. For a detailed description of this command, refer to iostat(1M).
You can display disk utilization information by using the iostat command with a time interval in seconds.
$ iostat 5 tty fd0 sd3 nfs1 nfs31 cpu tin tout kps tps serv kps tps serv kps tps serv kps tps serv us sy wt id 0 1 0 0 410 3 0 29 0 0 9 3 0 47 4 2 0 94 |
The first line of output shows the statistics since the last time the system was booted. Each subsequent line shows the interval statistics. The default is to show statistics for the terminal (tty), disks (fd and sd), and CPU (cpu).
The following table describes the fields in the iostat command output.
Table 24–4 Output From the iostat n Command
Device Type |
Field Name |
Description |
Terminal |
tin |
Number of characters in the terminal input queue |
tout |
Number of characters in the terminal output queue |
Disk |
bps |
Blocks per second |
tps |
Transactions per second |
serv |
Average service time, in milliseconds |
CPU |
us |
In user mode |
sy |
In system mode |
wt |
Waiting for I/O |
id |
Idle |
The following example shows disk statistics that were gathered every five seconds.
$ iostat 5 tty sd0 sd6 nfs1 nfs49 cpu tin tout kps tps serv kps tps serv kps tps serv kps tps serv us sy wt id 0 0 1 0 49 0 0 0 0 0 0 0 0 15 0 0 0 100 0 47 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 44 6 132 0 0 0 0 0 0 0 0 0 0 0 1 99 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 3 1 23 0 0 0 0 0 0 0 0 0 0 0 1 99 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100 |
Run the iostat -xtc command to get extended disk statistics.
$ iostat -xtc extended device statistics tty cpu device r/s w/s kr/s kw/s wait actv svc_t %w %b tin tout us sy wt id fd0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 0 0 0 0 100 sd0 0.0 0.0 0.4 0.4 0.0 0.0 49.5 0 0 sd6 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 nfs1 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 nfs49 0.0 0.0 0.0 0.0 0.0 0.0 15.1 0 0 nfs53 0.0 0.0 0.4 0.0 0.0 0.0 24.5 0 0 nfs54 0.0 0.0 0.0 0.0 0.0 0.0 6.3 0 0 nfs55 0.0 0.0 0.0 0.0 0.0 0.0 4.9 0 0 |
The iostat -xtc command displays a line of output for each disk. The output fields are described in the following table.
Table 24–5 Output From the iostat -xtc Command
Field Name |
Description |
r/s |
Reads per second |
w/s |
Writes per second |
kr/s |
Kbytes read per second |
kw/s |
Kbytes written per second |
wait |
Average number of transactions that are waiting for service (queue length) |
actv |
Average number of transactions that are actively being serviced |
svc_t |
%w |
Percentage of time that the queue is not empty |
%b |
Percentage of time that the disk is busy |
