Display file access operation statistics with the sar -a command.
$ sar -a SunOS touchstone 5.9 Generic sun4u 03/04/2003 00:00:00 iget/s namei/s dirbk/s 01:00:00 0 3 0 02:00:00 0 3 0 03:00:00 0 3 0 04:00:00 0 3 0 05:00:00 0 3 0 06:00:00 0 3 0 07:00:00 0 3 0 08:00:00 0 3 0 08:20:01 0 3 0 08:40:00 0 3 0 09:00:00 0 3 0 09:20:01 0 10 0 09:40:01 0 1 0 10:00:02 0 5 0 Average 0 4 0 |
The following table describes the operating system routines that are reported by the sar -a command.
Table 24–7 Output from the sar -a Command|
Field Name |
Description |
iget/s |
The number of requests made for inodes that were not in the directory name look-up cache (DNLC). |
namei/s |
The number of file system path searches per second. If namei does not find a directory name in the DNLC, it calls iget to get the inode for either a file or directory. Hence, most igets are the result of DNLC misses. |
dirbk/s |
The number of directory block reads issued per second. |
The larger the reported values, the more time the kernel is spending to access user files. The amount of time reflects how heavily programs and applications are using the file systems. The -a option is helpful for viewing how disk-dependent an application is.
