You must be superuser or working in a real-time shell to change a process from, or to, a real-time process.
Change the class of a process.
# priocntl -s -c class -i idtype idlist |
-s |
Lets you set the upper limit on the user priority range and change the current priority. |
-c class |
Specifies the class, TS or RT, to which you are changing the process. |
-i idtype idlist |
Uses a combination of idtype and idlist to identify the process or processes. The idtype specifies the type of ID, such as pid or UID. Use idlist to identify a list of pids or UIDs. |
Verify the process status.
# ps -ecl | grep idlist |
The following example shows how to change all the processes belonging to user 15249 to real-time processes.
# priocntl -s -c RT -i uid 15249 # ps -ecl | grep 15249 |
If, as superuser, you change a user process to the real-time class, the user cannot subsequently change the real-time scheduling parameters by using the priocntl -s command.
