Obtain the process ID of the process you want to display more information about.
# pgrep process |
process is the name of the process you want to display more information about.
The process ID is displayed in the first column of the output.
Display the process information you need.
# /usr/bin/pcommand pid |
pcommand |
Process tool command that you want to run. Table 23–3 lists these commands. |
pid |
Indicates the process ID. |
The following example shows how to use process tool commands to display more information about an lpsched process.
# pgrep lpsched 1
213
# pwdx 213 2
213: /
# ptree 213 3
213 /usr/lib/lpsched
# pfiles 213 4
213: /usr/lib/lpsched
Current rlimit: 4096 file descriptors
0: S_IFIFO mode:0000 dev:270,0 ino:67 uid:0 gid:0 size:0
O_RDWR
1: S_IFIFO mode:0000 dev:270,0 ino:67 uid:0 gid:0 size:0
O_RDWR
3: S_IFCHR mode:0666 dev:136,0 ino:35882 uid:0 gid:3 rdev:21,0
O_WRONLY FD_CLOEXEC
4: S_IFDOOR mode:0444 dev:275,0 ino:18526 uid:0 gid:0 size:0
O_RDONLY|O_LARGEFILE FD_CLOEXEC door to nscd[208]
5: S_IFREG mode:0664 dev:136,0 ino:64648 uid:71 gid:8 size:0
O_WRONLY
Obtains the process identification number for lpsched
Displays the current working directory for lpsched
Displays the process tree that containslpsched
Displays fstat and fcntl information
