Start a process with a designated priority.
# priocntl -e -c class -m userlimit -p pri command-name  |
 -e  |
 Executes the command.  |
 -c class  |
 Specifies the class within which to run the process. The valid classes are TS (timesharing), RT (real time), IA (interactive), FSS (fair share), or FX (fixed priority).  |
 -m userlimit  |
 Specifies the maximum amount you can raise or lower your priority, when using the -p option.  |
 Lets you specify the relative priority in the RT class, for a real-time thread. For a timesharing process, the -p option lets you specify the user-supplied priority, which ranges from -60 to +60.  |
Verify the process status.
# ps -ecl | grep command-name  |
The following example shows how to start the find command with the highest possible user-supplied priority.
# priocntl -e -c TS -m 60 -p 60 find . -name core -print # ps -ecl | grep find  |
