System Administration Guide: Advanced Administration
What's New in Managing System Resources?
New df, du, and ls Options
The df, du, and ls commands have a new -h option to display disk usage and file or file system sizes in powers of 1024. This option makes it easier to interpret the output of the df, du, and ls -l commands by providing disk space in kilobytes, Mbytes, Gbytes, or terabytes if the file or directory size is larger than 1024 bytes.
For more information, see df(1B), du(1), and ls(1).
For more information in this guide, see How to Display Information About Files and Disk Space.
Changing System Parameters
In previous versions of this book, there was a section on changing system parameters such as increasing the number of processes per user and shared memory segments. This section has been removed. For information on changing system tunable parameters, see Solaris Tunable Parameters Reference Manual.
In addition, information on setting up a network time server has been moved to “Time-Related Services” in System Administration Guide: Resource Management and Network Services.
Solaris Resource Management
Solaris resource management enables you to control how applications use available system resources.
You can also set up the extended accounting facility to monitor and record resource consumption on a task or process basis.
Extended accounting introduces a new, variable length general-purpose accounting file format that represents general groups of accounting data. It provides the ability to configure resource utilization recorded by the kernel in the various accounting files.
Solaris resource management features include:
The new default accounting configuration requires no administration. However, do not remove the /etc/project file, even if you do not use the extended accounting features. Users cannot log in to the system unless this file exists.
Use the following table to find more information about the extended accounting features in this release.
Solaris Resource Management Feature
For More Information
Turning on and off extended accounting
“Extended Accounting” in System Administration Guide: Resource Management and Network Services andacctadm(1M)
Description of the projects database
“Projects and Tasks” in System Administration Guide: Resource Management and Network Services andproject(4)
Directly collecting extended accounting data
libexacct(3LIB), getacct(2), putacct(2), and wracct(2)
