(Optional) Become superuser to display a crontab file that belongs to root or another user.
Display the crontab file.
$ crontab -l [username] |
Where username specifies the name of the user's account for which you want to create or edit a crontab file. To create or edit crontab files requires superuser privileges.
If you accidentally type the crontab command with no option, press the interrupt character for your editor. This character allows you to quit without saving changes. If you instead saved changes and exited the file, the existing crontab file is overwritten with an empty file.
The following example shows how to use the crontab -l command to display the contents of the user's default crontab file, the default root crontab file, and the crontab file belonging to another user.
$ crontab -l 13 13 * * * chmod g+w /home1/documents/*.book > /dev/null 2>&1 $ suPassword: # crontab -l #ident "@(#)root 1.19 98/07/06 SMI" /* SVr4.0 1.1.3.1 */ # # The root crontab should be used to perform accounting data collection. # # The rtc command is run to adjust the real time clock if and when # daylight savings time changes. # 10 3 * * * /usr/sbin/logadm 15 3 * * 0 /usr/lib/fs/nfs/nfsfind 1 2 * * * [ -x /usr/sbin/rtc ] && /usr/sbin/rtc -c > /dev/null 2>&1 30 3 * * * [ -x /usr/lib/gss/gsscred_clean ] && /usr/lib/gss/gsscred_clean # crontab -l jones 13 13 * * * cp /home/jones/work_files /usr/backup/. > /dev/null 2>&1 |
