You can display the size of directories by using the du command and options. Additionally, you can find the amount of disk space used by user accounts on local UFS file systems by using the quot command. For more information about these commands, see du(1) and quot(1M).
Display the size of one or more directories, subdirectories, and files by using the du command. Sizes are displayed in 512-byte blocks.
$ du [-as] [directory ...] |
du |
Displays the size of each directory you specify, including each subdirectory beneath it. |
-a |
Displays the size of each file and subdirectory, and the total number of blocks contained in the specified directory. |
-s |
Displays the total number of blocks contained in the specified directory. |
-h |
Displays the size of each directory in 1024 bytes. |
-H |
Displays the size of each directory in 1000 bytes. |
directory ... |
Identifies one or more directories you want to check. |
The following example shows the total sizes of two directories.
$ du -s /var/adm /var/spool/lp 130 /var/adm 40 /var/spool/lp |
The following example shows the sizes of two directories, all of the subdirectories and files they contain, and the total number of blocks contained in each directory.
$ du /var/adm /var/spool/lp 2 /var/adm/log 2 /var/adm/passwd 2 /var/adm/acct/fiscal 2 /var/adm/acct/nite 2 /var/adm/acct/sum 8 /var/adm/acct 2 /var/adm/sa 2 /var/adm/sm.bin 130 /var/adm 4 /var/spool/lp/admins 2 /var/spool/lp/fifos/private 2 /var/spool/lp/fifos/public 6 /var/spool/lp/fifos 2 /var/spool/lp/requests/starbug 4 /var/spool/lp/requests 2 /var/spool/lp/system 2 /var/spool/lp/tmp/starbug 2 /var/spool/lp/tmp/.net/tmp/starbug 4 /var/spool/lp/tmp/.net/tmp 2 /var/spool/lp/tmp/.net/requests/starbug 4 /var/spool/lp/tmp/.net/requests 10 /var/spool/lp/tmp/.net 14 /var/spool/lp/tmp 40 /var/spool/lp |
The following example shows directory sizes in 1024 bytes.
du -h /usr/share/audio 796K /usr/share/audio/samples/au 797K /usr/share/audio/samples 798K /usr/share/audio |
Display users, directories, or file systems, and the number of 1024-byte blocks used.
# quot [-a] [filesystem] |
-a |
Lists all users of each mounted UFS file system and the number of 1024-byte blocks used. |
filesystem |
Identifies a UFS file system. Users and the number of blocks used are displayed. |
The quot command works only on local UFS file systems.
In the following example, users of the root (/) file system are displayed. Then, users of all mounted UFS file systems are displayed.
# quot / /dev/rdsk/c0t0d0s0: 43340 root 3142 rimmer 47 uucp 35 lp 30 adm 4 bin 4 daemon # quot -a /dev/rdsk/c0t0d0s0 (/): 43340 root 3150 rimmer 47 uucp 35 lp 30 adm 4 bin 4 daemon /dev/rdsk/c0t0d0s6 (/usr): 460651 root 206632 bin 791 uucp 46 lp 4 daemon 1 adm /dev/rdsk/c0t0d0s7 (/export/home): 9 root |
