Display the quotas and disk use for all users on one or more file systems by using the repquota command.
Become superuser.
Display all quotas for one or more file systems, even if there is no usage.
# repquota [-v] -a filesystem |
-v |
Reports on quotas for all users, even those users who do not consume resources. |
-a |
Reports on all file systems. |
filesystem |
Reports on the specified file system. |
The following example shows output from the repquota command on a system that has quotas enabled on only one file system (/export/home).
# repquota -va
/dev/dsk/c0t3d0s7 (/export/home):
Block limits File limits
User used soft hard timeleft used soft hard timeleft
#301 -- 0 1 2.0 days 0 2 3
#341 -- 57 50 60 7.0 days 2 90 100
Block limits |
used |
Is the current block usage. |
soft |
Is the soft block limit. |
hard |
Is the hard block limit. |
timeleft |
Is the amount of time, in days, left on the quota timer. |
File limits |
used |
Is the current inode usage. |
soft |
Is the soft inode limit. |
hard |
Is the hard inode limit. |
timeleft |
