The following example shows the contents of the temporary file opened by edquota on a system where /files is the only mounted file system containing a quotas file in the root directory.
fs /files blocks (soft = 0, hard = 0) inodes (soft = 0, hard = 0) |
The following example shows the same line in the temporary file after quotas have been set up.
fs /files blocks (soft = 50, hard = 60) inodes (soft = 90, hard = 100) |
