After you have set up and turned on disk quotas and inode quotas, you can check for users who exceed their quotas. In addition, you can check quota information for entire file systems.
The following table describes the commands you use to check quotas.
Table 17–2 Commands for Checking Quotas|
Command |
Task |
Displays user quotas and current disk use, and information about users who are exceeding their quotas |
Displays quotas, files, and the amount of space owned for specified file systems |
You can display the quotas and disk use for individual users on file systems on which quotas have been activated by using the quota command.
Become superuser.
Display user quotas for mounted file systems where quotas are enabled.
# quota [-v] username |
-v |
Displays one or more users' quotas on all mounted file systems that have quotas. |
username |
Is the login name or UID of a user's account. |
The following example shows that the user account identified by UID 301 has one 1–Kbyte quota but has not used any disk space.
# quota -v 301 Disk quotas for bob (uid 301): Filesystem usage quota limit timeleft files quota limit timeleft /export/home 0 1 2 0 2 3 |
Filesystem |
Is the mount point for the file system. |
usage |
Is the current block usage. |
quota |
Is the soft block limit. |
limit |
Is the hard block limit. |
timeleft |
Is the amount of time, in days, left on the quota timer. |
files |
Is the current inode usage. |
quota |
Is the soft inode limit. |
limit |
Is the hard inode limit. |
timeleft |
Display the quotas and disk use for all users on one or more file systems by using the repquota command.
Become superuser.
Display all quotas for one or more file systems, even if there is no usage.
# repquota [-v] -a filesystem |
-v |
Reports on quotas for all users, even those users who do not consume resources. |
-a |
Reports on all file systems. |
filesystem |
Reports on the specified file system. |
The following example shows output from the repquota command on a system that has quotas enabled on only one file system (/export/home).
# repquota -va
/dev/dsk/c0t3d0s7 (/export/home):
Block limits File limits
User used soft hard timeleft used soft hard timeleft
#301 -- 0 1 2.0 days 0 2 3
#341 -- 57 50 60 7.0 days 2 90 100
Block limits |
used |
soft |
hard |
timeleft |
File limits |
used |
soft |
hard |
timeleft |
