Turn off file system quotas.
# quotaoff [-v] -a filesystem ... |
-v |
Displays a message from each file system when quotas are turned off. |
-a |
Turns off quotas for all file systems. |
filesystem |
Turns off quotas for one or more file systems you specify. More than one file system is specified by separating each file system name with a space. |
The following example shows how to turn off the quotas for the /export/home file system.
# quotaoff -v /export/home /export/home: quotas turned off |
