This section describes commands that enable you to change general system information.
Enter the new date and time.
# date mmddHHMM[[cc]yy] |
mm |
Month, using two digits. |
dd |
Day of the month, using two digits. |
HH |
Hour, using two digits and a 24-hour clock. |
MM |
Minutes, using two digits. |
cc |
Century, using two digits. |
yy |
Year, using two digits. |
See date(1) for more information.
Verify that you have reset your system's date correctly by using the date command with no options.
The following example shows how to use the date command to manually set a system's date and time.
# date Thu Jun 21 13:59:15 MDT 2003 # date 0621141003 Thu Jun 21 14:10:00 MDT 2003 |
Edit the message-of-the-day file, /etc/motd, to include announcements or inquiries to all users of a system when they log in. Use this feature sparingly, and edit this file regularly to remove obsolete messages.
Edit the /etc/motd file and add a message of your choice.
Edit the text to include the message that will be displayed during user login. Include spaces, Tabs, and Returns.
Verify the changes by displaying the contents of the /etc/motd file.
$ cat /etc/motd Welcome to the UNIX Universe. Have a nice day. |
The default message-of-the-day, provided when you install Solaris software, contains SunOS version information.
$ cat /etc/motd Sun Microsystems Inc. SunOS 5.9 Generic May 2002 |
The following example shows an edited /etc/motd file that provides information about system availability to each user who logs in.
$ cat /etc/motd The system will be down from 7:00 a.m to 2:00 p.m. on Saturday, July 7, for upgrades and maintenance. Do not try to access the system during those hours. Thank you. |
A system's host name is specified in several different locations.
Remember to update your name service database to reflect the new host name.
Use the following procedure to change or rename a system's name.
Become superuser.
Change the system's host name in the following files:
/etc/nodename
/etc/hostname.xxy
/etc/inet/hosts
/etc/net/ticlts/hosts
/etc/net/ticots/hosts
/etc/net/ticotsord/hosts
(Optional) If using a name service, change the system's host name in the hostfile.
Reboot the system to activate the new host name.
# init 6 |
