Enable a global core file path.
# coreadm -e global -g /var/core/core.%f.%p |
Display the current process core file path to verify the configuration.
# coreadm global core file pattern: /var/core/core.%f.%p init core file pattern: core global core dumps: enabled per-process core dumps: enabled global setid core dumps: disabled per-process setid core dumps: disabled global core dump logging: disabled |
