Reason Error Occurred |
How to Fix the Problem |
If files or directories with ACLs are copied or restored into the /tmp directory, the ACL attributes are lost. The /tmp directory is usually mounted as a temporary file system, which doesn't support UFS file system attributes such as ACLs. |
Copy or restore files into the /var/tmp directory instead. |
