metastat の出力はソートされていません。 構成リストを編集したい場合は、metastat -p コマンドの出力を入力して sort または grep コマンドを実行してください。
次に、metastat コマンドの出力例を示します。
# metastat
d50: RAID
State: Okay
Interlace: 32 blocks
Original device:
Device Start Block Dbase State Reloc Hot Spare
c1t4d0s5 330 No Okay Yes
c1t5d0s5 330 No Okay Yes
c2t4d0s5 330 No Okay Yes
c2t5d0s5 330 No Okay Yes
c1t1d0s5 330 No Okay Yes
c2t1d0s5 330 No Okay Yes
d1: Concat/Stripe
Stripe 0:
Device Start Block Dbase Reloc
c1t2d0s3 0 No Yes
d2: Concat/Stripe
Stripe 0:
c2t2d0s3 0 No Yes
d80: Soft Partition
Device: d70
State: Okay
Extent Start Block Block count
0 1 2097152
d81: Soft Partition
Device: d70
State: Okay
0 2097154 2097152
d70: Mirror
Submirror 0: d71
State: Okay
Submirror 1: d72
State: Okay
Pass: 1
Read option: roundrobin (default)
Write option: parallel (default)
d71: Submirror of d70
State: Okay
Stripe 0:
c1t3d0s3 0 No Okay Yes
Stripe 1:
c1t3d0s4 0 No Okay Yes
Stripe 2:
c1t3d0s5 0 No Okay Yes
d72: Submirror of d70
State: Okay
Stripe 0:
c2t3d0s3 0 No Okay Yes
Stripe 1:
c2t3d0s4 0 No Okay Yes
Stripe 2:
c2t3d0s5 0 No Okay Yes
hsp010: is empty
hsp014: 2 hot spares
Device Status Length Reloc
c1t2d0s1 Available 617652 blocks Yes
c2t2d0s1 Available 617652 blocks Yes
hsp050: 2 hot spares
c1t2d0s5 Available 4197879 blocks Yes
c2t2d0s5 Available 4197879 blocks Yes
hsp070: 2 hot spares
c1t2d0s4 Available 4197879 blocks Yes
c2t2d0s4 Available 4197879 blocks Yes
Device Relocation Information:
Device Reloc Device ID
c1t2d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1S200002103AF29
c2t2d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0P64Z00002105Q6J7
c1t1d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1EM00002104NP2J
c2t1d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N93J000071040L3S
c0t0d0 Yes id1,dad@s53554e575f4154415f5f53543339313430412525415933
次に、大容量記憶ボリューム (11T バイト) に対する metastat コマンドの出力例を示します。
# metastat d0
d0: Concat/Stripe
Size: 25074708480 blocks (11 TB)
Stripe 0: (interlace: 32 blocks)
c27t8d3s0 0 No Yes
c4t7d0s0 12288 No Yes
Stripe 1: (interlace: 32 blocks)
c13t2d1s0 16384 No Yes
c13t4d1s0 16384 No Yes
c13t6d1s0 16384 No Yes
c13t8d1s0 16384 No Yes
c16t3d0s0 16384 No Yes
c16t5d0s0 16384 No Yes
c16t7d0s0 16384 No Yes
c20t4d1s0 16384 No Yes
c20t6d1s0 16384 No Yes
c20t8d1s0 16384 No Yes
c9t1d0s0 16384 No Yes
c9t3d0s0 16384 No Yes
c9t5d0s0 16384 No Yes
c9t7d0s0 16384 No Yes
Stripe 2: (interlace: 32 blocks)
c27t8d2s0 16384 No Yes
c4t7d1s0 16384 No Yes
Stripe 3: (interlace: 32 blocks)
c10t7d0s0 32768 No Yes
c11t5d0s0 32768 No Yes
c12t2d1s0 32768 No Yes
c14t1d0s0 32768 No Yes
c15t8d1s0 32768 No Yes
c17t3d0s0 32768 No Yes
c18t6d1s0 32768 No Yes
c19t4d1s0 32768 No Yes
c1t5d0s0 32768 No Yes
c2t6d1s0 32768 No Yes
c3t4d1s0 32768 No Yes
c5t2d1s0 32768 No Yes
c6t1d0s0 32768 No Yes
c8t3d0s0 32768 No Yes
詳細は、metastat(1M) のマニュアルページを参照してください。
