Solaris 9 9/05 Release Notes
Euro Character Input Sequences That Are Alt Key-Based and Meta Key-Based
The following nonstandard-input key sequences for the Euro character in Solaris Unicode/UTF-8 locales might not be supported in a future release:
Note –
In the key sequences, a hyphen indicates simultaneous keystrokes. A plus sign indicates consecutive keystrokes.
The following are the recommended standard-input key sequences:
If the keyboard has no Alt Graph or Compose key, use the following key sequence:
