The following Documentation CD installation bugs apply to the Solaris 9 9/05 release.
If you run the Solaris 9 9/05 Documentation CD uninstaller in Uninstall All mode, the uninstaller removes only those documentation packages that are installed by default.
Workaround: Run the uninstaller in Uninstall Partial mode. Select the specific packages that you want to uninstall.
If you use the Solaris 9 9/05 Documentation CD installer program with the nodisplay option, the verify panel might not page correctly.
Workaround: Do not specify the nodisplay option with the Solaris 9 9/05 Documentation CD installer program. Use the graphical user interface (GUI) mode to install the Solaris 9 9/05 Documentation CD.
