The following CDE bugs apply to the Solaris 9 9/05 OS.
The following UTF-8 locales are missing when the login server starts and the Common Desktop Environment (CDE) login service is launched:
ar_SA.UTF-8
el_GR.UTF-8
nl_BE.UTF-8
nl_NL.UTF-8
pt_PT.UTF-8
Workaround: To use these locales, log in to any other UTF-8 locale. Then, set the LC_ALL variable at the command line. For example:
export LC_ALL=ar_SA.UTF-8
The workaround applies only to SPARC based systems. These locales are unavailable in x86 based systems.
The Removable Media auto run capability in the CDE desktop environment has been temporarily removed from the Solaris 9 9/05 software.
Workaround: To use the auto run function for a CD-ROM or another removable media volume, you must do one of the following:
Run the volstart program from the top level of the removable media file system.
Follow the instructions that are included with the CD for access from outside of CDE.
dtmail crashes after connecting with the IMAP server if the FontList option is specified when dtmail is launched from the command line. See the following example:
/usr/dt/bin/dtmail -xrm "Dtmail*FontList: -*-r-normal-*:" |
The following error message is displayed:
Segmentation Fault |
This problem occurs in both the C and ja locales.
Workaround: Do not specify the FontList option when you launch dtmail from the command line.
If you try to read an email message with many long lines in any of the Solaris 9 9/05 Unicode or UTF-8 locales, CDE Mailer (dtmail) appears to hang. The message does not display immediately.
Workaround: Choose one of the following workarounds:
Enlarge the dtmail Mailbox window to accommodate 132 columns.
Disable the Complex Text Layout feature by following these steps:
Become superuser.
Change directories to your system's locale directory.
# cd /usr/lib/locale/locale-name |
In the previous example, locale-name refers to the name of your system's Solaris 9 9/05 Unicode or UTF-8 locale.
Rename the locale layout engine category.
# mv LO_LTYPE LO_LTYPE- |
Rename the category for the locale layout engine to the original name (LO_LTYPE) before you apply any patches to the locale layout engine.
After you delete the last item from the desktop, the item is restored from the handheld device to the desktop when you synchronize your handheld device. Examples of items that you might delete, and then have restored, are the last appointment in your Calendar or the last address in the Address Manager.
Workaround: Manually delete the last entry from the handheld device prior to synchronization.
If you exchange multibyte data between a PDA device and Solaris CDE, the data might be corrupted in both environments.
Workaround: Back up your data on your personal computer with the PDA backup utility before you run the SolarisTM PDASync application. If you accidentally exchange multibyte data and corrupt that data, restore your data from the backup.
