Solaris 9 9/05 HW Release Notes
Installation Bugs That Occur During an Upgrade
The following installation bugs occur during an upgrade to the Solaris 9 9/05 HW release.
Installer Text Display Problem When Using Solaris Live Upgrade (4736488)
When using the Solaris Live Upgrade luupgrade(1M) command with the -i option to complete an upgrade of an inactive boot environment, the text that the installers display might be unreadable in some languages. The text is corrupted when the installers request fonts that do not exist on the older release that is on the current boot environment.
Workaround: Choose one of the following workarounds:
SPARC: Removal of SUNWjxcft Package Records Error During Upgrade (4525236)
When you upgrade from the Solaris 8 software to the Solaris 9 or the Solaris 9 9/05 HW release, a problem is encountered when the SUNWjxcft package is removed. The following error message is recorded in the upgrade_log file:
Removing package SUNWjxcft:
Can't open /a/usr/openwin/lib/locale/ja/X11/fonts/TTbitmaps/fonts.upr
Can't open /a/usr/openwin/lib/locale/ja/X11/fonts/TTbitmaps/fonts.scale
Can't open /a/usr/openwin/lib/locale/ja/X11/fonts/TTbitmaps/fonts.alias
Can't open /a/usr/openwin/lib/locale/ja/X11/fonts/TT/fonts.upr
Can't open /a/usr/openwin/lib/locale/ja/X11/fonts/TT/fonts.scale
Can't open /a/usr/openwin/lib/locale/ja/X11/fonts/TT/fonts.alias
Removal of <SUNWjxcft> was successful
Workaround: Ignore the error message.
Upgrading to Solaris 9 9/05 HW Release Might Disable Existing Secure Shell Daemon (sshd) (4626093)
If you upgrade to the Solaris 9 9/05 HW release on a system that is running a third-party Secure Shell, such as OpenSSH from the /etc/init.d/sshd daemon, the upgrade disables the existing Secure Shell daemon. During an upgrade, the Solaris 9 9/05 HW software overwrites the contents of /etc/init.d/sshd.
Upgrade Fails if /export Directory Is Near Capacity (4409601)
If the /export directory is near full capacity when you upgrade to the Solaris 9 9/05 HW release, space requirements for /export are miscalculated. The upgrade then fails. This problem commonly occurs if a diskless client is installed. Another instance of when the problem occurs is when third-party software is installed in the /export directory. The following message is displayed:
WARNING: Insufficient space for the upgrade.
Workaround: Before you upgrade, choose one of the following workarounds:
Upgrading Diskless Client Servers and Clients (4363078)
If your system currently supports diskless clients that were installed with the Solstice AdminSuiteTM 2.3 Diskless Client tool, you must perform the following two steps:
  1. Delete all existing diskless clients that are the same Solaris version and architecture as the server.
  2. Install or upgrade to the Solaris 9 9/05 HW release.
For specific instructions, see the System Administration Guide: Basic Administration.
If you attempt to install the Solaris 9 9/05 HW software over existing diskless clients, the following error message might be displayed:
The Solaris Version (Solaris version-number) on slice
<xxxxxxxx> cannot
be upgraded.
There is an unknown problem with the software configuration installed
on this disk.
In this error message, version-number refers to the Solaris version that is currently running on your system. <xxxxxxxx> refers to the slice that is running this version of the Solaris software.
