Solaris 9 9/05 HW Release Notes
Documentation CD Installation Bugs
The following Documentation CD installation bugs apply to the Solaris 9 9/05 HW release.
Uninstall Mode of Solaris 9 9/05 HW Documentation CD uninstaller Utility Does Not Work Properly (4675797, 4627776)
If you run the Solaris 9 9/05 HW Documentation CD uninstaller in Uninstall All mode, the uninstaller removes only those documentation packages that are installed by default.
Workaround: Run the uninstaller in Uninstall Partial mode. Select the specific packages that you want to uninstall.
Documentation CD Verify Panel Might Not Page in Command-Line Interface Mode (4520352)
If you use the Solaris 9 9/05 HW Documentation CD installer program with the nodisplay option, the verify panel might not page correctly.
Workaround: Do not specify the nodisplay option with the Solaris 9 9/05 HW Documentation CD installer program. Use the graphical user interface (GUI) mode to install the Solaris 9 9/05 HW Documentation CD.
