Solaris 9 9/05 HW Release Notes
SPARC: Removing Patches After Upgrade Might Corrupt WBEM Repository (4820614)
The WBEM Repository Common Information Model (CIM) database can be corrupted under the following conditions:
If the WBEM Repository is corrupted, the following error message is displayed in the Solaris Management Console Log Viewer:
CIM_ERR_FAILED:
/usr/sadm/lib/wbem/../../../../var/sadm/wbem/logr/
preReg/PATCH113829install/Solaris_Application.mof,18,ERR_SEM,
ERR_EXC_SET_CLASS,CIM_ERR_FAILED:Other Exception:
java.io.StreamCorruptedException: invalid stream header
Workaround: Choose one of the following workarounds:
