If you use the default Solaris JumpStartTM profile on the Solaris 9 9/05 HW media to install multiple locales on a system with a small disk, the installation might fail. This problem might occur under the following conditions:
You use the Solaris JumpStart profile that is the default to install any locale other than the C locale on a system with a 2.1-Gbyte disk.
You use the Solaris JumpStart profile that is the default to install two or more locales on a system with a 4-Gbyte disk.
