The Solaris 9 9/05 HW Release Notes contain installation problem details and other information that are specific to the SolarisTM 9 9/05 HW Operating System. More hardware-related issues in this release are described in the Solaris 9 9/05 HW Release Notes Supplement for Sun Hardware. For all other information about the Solaris 9 9/05 OS, refer to the Solaris 9 documentation at http://docs.sun.com. Certain Solaris 9 9/04documents contain information that remains applicable to this latest release.
The Solaris software runs on two platforms, SPARC® and x86. The Solaris software also runs on 64-bit and 32-bit address spaces. The information in this document pertains to both platforms and address spaces unless otherwise specified in a special chapter, section, note, bulleted item, figure, table, or example.
The Solaris 9 9/05 HW release provides Solaris 9 OS support for specific SPARC hardware products. It is not available for x86 platforms, which can continue using the existing Solaris 9 9/05 release. This book retains information that applies to x86 platforms using the Solaris 9 9/05 software.
These notes are for users and system administrators who install and use the Solaris 9 9/05 HW software.
This version of the software is only available for SPARC platforms. If you are using Solaris 9 9/05 software on SPARC or x86 platforms, you should instead read the Solaris 9 9/05 Release Notes.
The following documentation applies to Solaris 9 9/05 HW:
GNOME 2.0 Desktop 9/04 Collection
iPlanet Directory Server 5.1 Collection (Solaris Edition)
Solaris 9 9/04 About What's New Collection
Solaris 9 9/04 Reference Manual Collection
Solaris 9 9/04 Software Developer Collection
Solaris 9 9/04 System Administrator Collection
Solaris 9 9/05 on Sun Hardware Collection
Solaris 9 9/05 HW Release and Installation Collection
Solaris 9 Common Desktop Environment Developer Collection
Solaris 9 KCMS Collection
Solaris 9 User Collection
Sun ONE Application Server 7 Reference Manual Collection
Sun ONE Application Server 7, Update 3
Sun ONE Message Queue 3.0.1 Collection (Solaris Edition)
You might need to refer to the following documentation when you install Solaris software:
GNOME 2.0 Desktop Collection
Solaris 9 Start Here
Solaris 9 9/04 Release Notes
Solaris 9 System Administrator Collection
Sun ONE Application Server 7 Collection (Solaris Edition)
For information about the SunTM JavaTM Enterprise System, see the Sun Java Enterprise 2004Q2 at http://docs.sun.com. You can find the Sun Java Enterprise System 2004Q2 Release Notes.
For information on current CERT advisories, see the official CERT web site at http://www.cert.org.
For some hardware configurations, you might need supplemental hardware-specific instructions for installing the Solaris software. If your system requires hardware-specific actions at certain points, the manufacturer of your hardware has provided supplemental Solaris installation documentation. Refer to those materials, such as Solaris 9 9/05 Sun Hardware Platform Guide, for hardware-specific installation instructions.
Third-party URLs are referenced in this document and provide additional, related information.
Sun is not responsible for the availability of third-party web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other material on or available from such sites or resources. Sun will not be responsible or liable for any damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through any such sites or resources.
The Sun web site provides information about the following additional resources:
The following table describes the typographic conventions that are used in this book.
Table P–1 Typographic Conventions|
Typeface |
Meaning |
Example |
AaBbCc123 |
The names of commands, files, and directories, and onscreen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 |
What you type, contrasted with onscreen computer output |
machine_name% su Password: |
aabbcc123 |
Placeholder: replace with a real name or value |
The command to remove a file is rm filename. |
AaBbCc123 |
Book titles, new terms, and terms to be emphasized |
Read Chapter 6 in the User's Guide. A cache is a copy that is stored locally. Do not save the file. Note: Some emphasized items appear bold online. |
The following table shows the default UNIX® system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
C shell |
machine_name% |
C shell for superuser |
machine_name# |
Bourne shell and Korn shell |
Bourne shell and Korn shell for superuser |
