Some Solaris 9 9/05 HW documentation collections might be unexpectedly removed from your system under the following circumstances:
You install both the Solaris 9 9/05 HW Documentation 1 of 2 and 2 of 2 CDs on your system.
You then use the prodreg utility or the Solaris 9 9/05 HW Documentation CD installer program to remove certain documentation packages.
The Solaris 9 9/05 HW Documentation CD 1 of 2 and 2 of 2 have three collections in common. If you remove the packages that contain these collections from either of the Solaris 9 9/05 HW Documentation 1 of 2 or 2 of 2 CD installations, the package is removed for both installations.
The following table lists the packages that might be removed unexpectedly.
Table 2–2 Solaris 9 9/05 HW Documentation Packages Contained on Both Solaris 9 9/05 HW Documentation CDs|
HTML Package Names |
PDF Package Names |
Collection Description |
SUNWaadm |
SUNWpaadm |
Solaris 9 System Administrator Collection |
SUNWdev |
SUNWpdev |
Solaris 9 Developer Collection |
SUNWids |
SUNWpids |
iPlanet Directory Server 5.1 Collection |
Workaround: Choose one of the following workarounds:
If the uninstall process unexpectedly removed these documentation packages, and you want these packages on your system, reinstall the packages from the Solaris 9 9/05 HW Documentation 1 of 2 or 2 of 2 CDs.
To avoid this problem, use the pkgrm utility to remove the packages that you want to eliminate from your system.
