The schema provided with the Sun Open Net Environment (Sun ONE) Directory Server (formerly iPlanet Directory Server) 5.1 differs from the schema that is specified in RFC 2256 for the groupOfNames and groupOfUniquenames object classes. In the schema provided, the member and uniquemember attribute types are optional. RFC 2256 specifies at least one value for these types must be present in the respective object class.
The aci attribute is an operational attribute that is not returned in a search, unless you explicitly request the attribute.
