Solaris 9 9/05 HW Package List
Chapter 1 Solaris 9 9/05 HW Operating Environment Package List
This chapter lists and describes the packages included in the Solaris 9 9/05 HW operating environment, in the following platform-specific table:
The Solaris 9 9/05 HW release is not available for x86 platforms. For x86 platforms that use the Solaris 9 9/05 release, see the Solaris 9 9/05 Package List.
Table 1–1 Solaris 9 9/05 HW (SPARC Platform Edition) Operating Environment Packages
Package
Description
Entire+OEM
Entire
Developer
End User
Core
IPLTadcon
Administration Server Console Client package
IPLTadman
Administration Server Documentation
IPLTadmin
IPLTcons
Console Client Base package
IPLTdscon
Directory Server Console
IPLTdsman
Directory Server Documentation
IPLTdsr
Directory Server
IPLTdsu
Directory Server
IPLTjss
Network Security Services for JavaTM
IPLTnls
Nationalization Languages and Localization Support
IPLTnspr
Netscape Portable Runtime Interface
IPLTnss
IPLTpldap
PerLDAP
NATEvplr
Nature Tech platform links (root)
NATEvplu
Nature Tech usr/platform links
NSCPcom
This package contains the application and configuration files of Netscape Communicator 4.78 supporting U.S. security.
SMEvplr
SME platform links,(Root)
SMEvplu
SME platform links,(usr)
SUNW1251f
Russian additional locale fonts (1251)
SUNW1394h
Sun IEEE1394 Header Files
SUNW1394x
IEEE1394 Framework and OpenHCI Driver (64-bit)
SUNW5xmft
Traditional Chinese (BIG5) X Windows Platform required Fonts Package
SUNWGlib
GLIB - Library of useful routines for C programming
SUNWGtkr
GTK - The GIMP Toolkit (Root)
SUNWGtku
GTK - The GIMP Toolkit (Usr)
SUNWTcl
Tcl - Tool Command Language
SUNWTiff
The TIFF Library
SUNWTiffx
libtiff - library for reading and writing TIFF (64-bit)
SUNWTk
Tk - TCL GUI Toolkit
SUNWa2psr
a2ps - GNU Any to PostScript filter (root) 4.13
SUNWa2psu
a2ps - GNU Any to PostScriptTM filter (user) 4.13
SUNWaccr
utilities for accounting and reporting of system activity
SUNWaccu
SUNWaclg
Apache Common Logging
SUNWadmap
Software used to perform system administration tasks
SUNWadmc
Core software libraries used for system administration
SUNWadmfw
This package contains the system and network administration libraries and services.
SUNWadmj
Java libraries used for system administration tools
SUNWadmr
Root programs and scripts for initializing system installation.
SUNWafb
Device driver for the UPA Bus Elite3D graphics accelerator
SUNWafbcf
Configuration software for the UPA Bus Elite3D graphics accelerator
SUNWafbr
Boot-time device initialization support for the UPA Bus Elite3D graphics accelerator
SUNWafbw
X server loadable module for the UPA Bus Elite3D graphics accelerator
SUNWafbx
Device driver for the UPA Bus Elite3D graphics accelerator (64-bit)
SUNWant
The Jakarta ANT Java/XML-based build tool
SUNWapchd
The Apache HTTP server (1.3.29) (documentation)
SUNWapchr
The Apache HTTP server program (1.3.29) (root components)
SUNWapchu
The Apache HTTP server program (1.3.29) (usr components)
SUNWapct
Appcert utility for application ABI stability checking
SUNWarc
system libraries in archive (ar) format for software development of statically linked executables
SUNWarcx
SUNWarrf
X11 fonts for Arabic character set (required fonts)
SUNWasac
Application Server Admin Client
SUNWascmn
Application Server common components
SUNWasdem
Application Server Sample Applications
SUNWasman
Application Server Manual Pages
SUNWasr
Application Server (root)
SUNWast
administrative utilities for improving system security by monitoring or restricting access to system files and directories
SUNWasu
Application Server (usr)
SUNWatfsr
configuration and start-up files for the AutoFS filesystem
SUNWatfsu
utilities and a daemon (automountd) for the AutoFS filesystem
SUNWauda
SunOSTM audio applications
SUNWaudd
SunOS audio device drivers using the new audio driver architecture
SUNWauddx
SunOS audio device drivers using the new audio driver architecture (64-bit)
SUNWaudf
SunOS audio sound files
SUNWaudh
SunOS C/C++ header files for audio drivers and applications
SUNWaudit
Java BSM audit interface / AuditService Implementation
SUNWauditx
Java BSM 64-bit audit interface / AuditService Implementation
SUNWbash
GNU Bourne-Again shell (bash)
SUNWbcp
utilities to provide a binary-compatible execution environment for SunOS 4.x applications
SUNWbip
Basic IP commands (/usr/sbin/ping, /bin/ftp)
SUNWbnur
configuration and start-up files for UUCP utilities
SUNWbnuu
UUCP utilities and daemon
SUNWbsr
Boot Server daemons (Root)
SUNWbsu
Boot Server daemons (Usr)
SUNWbtool
software development utilities, including ar, dis, dump, elfdump, lex, lorder, mcs, nm, prof, ranlib, rpcgen, size, strip, tsort, and yacc
SUNWbtoox
64-bit libraries for software development utilities, including lex and yacc
SUNWbzip
The bzip compression utility
SUNWbzipx
The bzip compression library (64-bit)
SUNWcar
core software for a specific hardware platform group
SUNWcarx
core 64-bit software for a specific hardware platform group
SUNWcdrw
utility for writing to CD-R/RW and DVD{+-}R/RW DISKs
SUNWcea
Sun GigaSwift Ethernet Adapter Driver 32 bit adb Macros
SUNWceax
Sun GigaSwift Ethernet Adapter Driver 64 bit adb Macros
SUNWced
Sun GigaSwift Ethernet Adapter (32-bit Driver)
SUNWcedu
Sun GigaSwift Ethernet Adapter Headers
SUNWcedx
Sun GigaSwift Ethernet Adapter (64-bit Driver)
SUNWcg6
kernel device driver for the GX frame buffer
SUNWcg6h
SunOS C/C++ header files for development of software for the GX frame buffer
SUNWcg6x
kernel device driver (64-bit) for the GX frame buffer
SUNWciu8
Simplified Chinese (EUC) iconv modules for UTF-8
SUNWciu8x
Simplified Chinese (EUC) iconv modules for UTF-8 (64-bit)
SUNWcpc
Kernel support for CPU Performance Counters
SUNWcpcu
CPU Performance Counter libraries and utilities
SUNWcpcux
CPU Performance Counter libraries and utilities (64-bit)
SUNWcpcx
Kernel support for CPU Performance Counters (64-bit)
SUNWcpp
Solaris cpp
SUNWcpr
Suspend, Resume package
SUNWcprx
Suspend, Resume package (64-bit)
SUNWcsd
core entries for /dev and /devices needed for the initial boot of Solaris
SUNWcsl
core shared libraries for a specific instruction-set architecture
SUNWcslx
core 64-bit libraries for a specific instruction-set architecture
SUNWcsr
core software for a specific instruction-set architecture
SUNWcstl
Apptrace utility for application tracing, including shared objects
SUNWcstlx
Apptrace shared objects (64-bit)
SUNWcsu
SUNWcsxu
core 64-bit software for a specific instruction-set architecture
SUNWcti2x
I2C and System Controller and Status Drivers for Netra ct cPCI platform (64-bit)
SUNWctlu
Print utilities for CTL locales
SUNWctpls
This package contains the layout interface for language engines.
SUNWctplx
This package contains the 64 bit layout interface for language engines.
SUNWcvc
Network Console
SUNWcvcr
Network Console daemon and rc script
SUNWcvcx
Network Console (64-bit)
SUNWcxmft
Simplified Chinese (EUC) X Windows Platform Required Fonts
SUNWdclnt
Solaris Diskless Client Management Application
SUNWdcsr
Domain Configuration Server, (Root)
SUNWdcsu
SUNWdesktop-media-player-share
Desktop Media Player - platform independent files, /usr/share
Desktop Media Player - platform dependent files, /usr filesystem
SUNWdfb
kernel device drivers for dumb frame buffers
SUNWdfbh
SunOS C/C++ header files for development of software for dumb frame buffers
SUNWdhcm
Graphical management interface for the DHCP server
SUNWdhcsb
Binary File Format Public module exporting Version 1 of the Service Provider Interface. Used to store DHCP data, this module has much better performance than the ASCII files and nisplus public modules.
SUNWdhcsr
Root filesystem portion of the SunOS BOOTP/DHCP service, which uses the BOOT Protocol and/or Dynamic Host Configuration Protocol to provide network configuration parameters to BOOTP/DHCP clients. Adminstration utilities for the service are included.
SUNWdhcsu
Usr filesystem portion of the SunOS BOOTP/DHCP service, which uses the BOOT Protocol and/or Dynamic Host Configuration Protocol to provide network configuration parameters to BOOTP/DHCP clients. Adminstration utilities for the service are included.
SUNWdial
Streams module for the Dials and Buttons devices
SUNWdialh
Header files for the Dials and Buttons devices
SUNWdialx
Streams module for the Dials and Buttons devices (64-bit)
SUNWdmfex
Sun Davicom 10/100Mb Ethernet Driver (64-bit)
SUNWdoc
utilities and fonts for development, display, and production of documentation such as manual pages (nroff/troff)
SUNWdpl
system libraries compiled with profiling for software development performance measurement
SUNWdplx
64-bit system libraries compiled with profiling for software development performance measurement
SUNWdrcrx
Dynamic Reconfiguration Modules for Sun FireTM 15000 (64-bit)
SUNWdtab
CDE Desktop Application Builder
SUNWdtbas
CDE application basic runtime environment
SUNWdtbax
CDE application basic runtime environment (64-bit)
SUNWdtcor
Solaris Desktop /usr/dt filesystem anchor
SUNWdtct
UTF-8 Code Conversion Tool
SUNWdtdem
CDE Demos
SUNWdtdmn
Daemons for the common desktop environment, CDE
SUNWdtdst
CDE Desktop Applications
SUNWdtdte
Solaris Desktop Login Environment
SUNWdtezt
Address Manager, Process Manager, File Finder, Perfmeter, Workstation Info
SUNWdthe
CDE Help Runtime environment
SUNWdthed
CDE Help Developer Environment
SUNWdthev
CDE Help Volumes
SUNWdthez
Desktop Power Pack Help Volumes
SUNWdticn
Icons for the common desktop environment, CDE
SUNWdtim
Solaris CDE Image ViewerTM
SUNWdtinc
CDE Include files
SUNWdtjxt
Java Extensions
SUNWdtlog
System boot for Desktop Login
SUNWdtma
Manual pages for the common desktop environment, CDE
SUNWdtmad
Common Desktop Environment (CDE) Developer manual pages
SUNWdtmaz
Manual pages for Address Manager, Process Manager, File Finder, Perfmeter, Workstation Info
SUNWdtnsc
This package contains Netscape Componentization Support for CDE
SUNWdtscm
CDE Dtpower Schemes
SUNWdtwm
CDE Desktop Window Manager
SUNWefclx
Embedded FCode Libraries (64-bit)
SUNWefcr
Embedded FCode Interpreter
SUNWefcux
Embedded FCode Interpreter (64-bit)
SUNWefcx
Embedded FCode Interpreter Drivers (64-bit)
SUNWeridx
Sun RIO 10/100 Mb Ethernet Drivers (64-bit)
SUNWespgs
espgs - ESP GhostScript 7.05.6
SUNWesu
additional UNIX system utilities, including awk, bc, cal, compress, diff, dos2unix, last, rup, sort, spell, sum, uniq, and uuencode
SUNWesxu
additional 64-bit UNIX system utilities
SUNWeuodf
American English/UTF-8 Core OPENLOOK Desktop Files
SUNWeurf
European codeset fonts
SUNWeuxwe
American English/UTF-8 X Window Environment
SUNWfac
utilities and resources for a Form and Menu Language Interpreter (FMLI) execution environment
SUNWfbc
Generic frame buffer configuration utility
SUNWfcip
Sun FCIP IP/ARP over FibreChannel Device Driver
SUNWfcipx
Sun FCIP IP/ARP over FibreChannel Device Driver (64-bit)
SUNWfcp
Sun FCP SCSI Fibre Channel Device Driver
SUNWfcpx
Sun FCP SCSI Fibre Channel Device Driver (64-bit)
SUNWfctl
fctl module and fp device driver
SUNWfctlx
fctl module and fp device driver (64-bit)
SUNWfdl
Font Downloader for Postscript network printers
SUNWffb
Device driver for the UPA Bus Creator graphics accelerator
SUNWffbcf
Configuration utility for the UPA Bus Creator graphics accelerator
SUNWffbw
X server loadable module for the UPA Bus Creator graphics accelerator
SUNWffbx
Device driver for the UPA Bus Creator graphics accelerator (64-bit)
SUNWffiltersr
foomatic-filters - Foomatic Print Filters (root) 3.0
SUNWffiltersu
foomatic-filters - Foomatic Print Filters (user) 3.0
SUNWfns
Federated Naming Service (XFN) - core libraries and utilities
SUNWfnsx5
Federated Naming Service (XFN) - support for X.500 Directory
SUNWfnsx
Federated Naming Service (XFN) - core libraries and utilities (64-bit)
SUNWfnx5x
Federated Naming Service (XFN) - support for X.500 Directory (64-bit)
SUNWfontconfig-64
Fontconfig library (64-bit)
SUNWfontconfig-docs
Fontconfig library documentation
SUNWfontconfig-root
Fontconfig library configuration files (/etc/fonts)
SUNWfontconfig
Fontconfig library
SUNWfppd
foomatic_ppds - Foomatic Print PPDs 3.0
SUNWfreetype2-64
FreeType 2.1.2 Font library (64-bit)
SUNWfreetype2
SUNWfruid
FRU ID prtfru command and libfru library
SUNWfruip
FRU ID platform data module and access library
SUNWfruix
FRU ID Library (64-bit)
SUNWfss
core software for the fair share scheduler
SUNWfssx
core software for the fair share scheduler (64-bit)
SUNWftdur
Driver Hardening Test Harness
SUNWftduu
Driver Hardening Test Harness (usr)
SUNWftdux
Driver Hardening Test Harness (64-bit)
SUNWftpr
FTP Server Configuration Files
SUNWftpu
FTP Server and Utilities
SUNWfwdcd
IEEE 1394 Video Conferencing demo (64-bit)
SUNWfwdcu
IEEE 1394 Video Conferencing support (64-bit)
SUNWfwdcx
IEEE 1394 Video Conferencing Class Driver
SUNWgcmn
Common GNU package
SUNWged
Sun Gigabit Ethernet Adapter 32Bit Driver
SUNWgedu
Sun Gigabit Ethernet Adapter Headers
SUNWgedx
Sun Gigabit Ethernet Adapter 64Bit Driver
SUNWgfb
Device driver for the UPA Bus Sun XVR-1000 Graphics Accelerator
SUNWgfbcf
Configuration utility for the UPA Bus Sun XVR-1000 Graphics Accelerator
SUNWgfbr
Boot-time device initialization support for the UPA Bus Sun XVR-1000 Graphics Accelerator
SUNWgfbw
X server loadable module for the UPA Bus Sun XVR-1000 Graphics Accelerator
SUNWgfbx
Device driver for the UPA Bus Sun XVR-1000 Graphics Accelerator (64-bit)
SUNWggrp
ggrep - GNU grep utilities
SUNWgimpprint
gimpprint - Drivers for Canon, Epson, Lexmark & PCL printers 4.2.5
SUNWglmr
rasctrl environment monitoring driver for i2c, (Root) (32-bit)
SUNWglmx
rasctrl environment monitoring driver for i2c, (Root) (64-bit)
SUNWglt
Layout Table Generation Utility
SUNWgnome-a11y-libs-devel-share
GNOME
GNOME
SUNWgnome-a11y-libs-share
GNOME accessibility framework - platform independent files, /usr/share
SUNWgnome-a11y-libs
GNOME accessibility framework - platform dependent files, /usr filesystem
SUNWgnome-audio-devel-share
GNOME audio support framework - developer files - platform independent, /usr/share
SUNWgnome-audio-root
GNOME audio support framework - platform dependent files, / filesystem
SUNWgnome-audio-share
GNOME audio support framework - platform independent files, /usr/share
SUNWgnome-audio
GNOME audio support framework - platform dependent files, /usr filesystem
SUNWgnome-base-libs-64-root
GNOME base GUI libraries (64-bit) - platform dependent files, / filesystem
GNOME base GUI libraries (64-bit) - platform dependent files, /usr filesystem
SUNWgnome-base-libs-devel-share
GNOME base GUI libraries - developer files - platform independent, /usr/share
SUNWgnome-base-libs-root
GNOME base GUI libraries - platform dependent files, / filesystem
SUNWgnome-base-libs-share
GNOME base GUI libraries - platform independent files, /usr/share
SUNWgnome-base-libs
GNOME base GUI libraries - platform dependent files, /usr filesystem
SUNWgnome-calculator-share
GNOME calculator utility - platform independent files, /usr/share
GNOME calculator utility - platform dependent files, /usr filesystem
SUNWgnome-cd-root
GNOME CD player utility - platform dependent files, / filesystem
SUNWgnome-cd-share
GNOME CD player utility - platform independent files, /usr/share
SUNWgnome-cd
GNOME CD player utility - platform dependent files, /usr filesystem
SUNWgnome-character-map-share
GNOME character map utility - platform independent files, /usr/share
GNOME character map utility - platform dependent files, /usr filesystem
SUNWgnome-common-devel-share
GNOME common development tools and libraries - developer files
SUNWgnome-component-devel-share
GNOME CORBA ORB and component framework - developer files - platform independent, /usr/share
SUNWgnome-component-root
GNOME CORBA ORB and component framework - platform dependent files, / filesystem
SUNWgnome-component-share
GNOME CORBA ORB and component framework - platform independent files, /usr/share
SUNWgnome-component
SUNWgnome-config-devel-share
GNOME configuration framework - developer files - platform independent, /usr/share
SUNWgnome-config-root
GNOME configuration framework - platform dependent files, / filesystem
SUNWgnome-config-share
GNOME configuration framework - platform independent files, /usr/share
SUNWgnome-config
GNOME configuration framework - platform dependent files, /usr filesystem
SUNWgnome-desktop-prefs-root
GNOME desktop wide preference configuration tools - platform dependent files, / filesystem
SUNWgnome-desktop-prefs-share
GNOME desktop wide preference configuration tools - platform independent files, /usr/share
GNOME desktop wide preference configuration tools - platform dependent files, /usr filesystem
SUNWgnome-dtlogin-integration
dtlogin configuration files for the GNOME desktop - platform dependent files, /usr filesystem
SUNWgnome-file-mgr-root
GNOME file manager and support libraries - platform dependent files, / filesystem
SUNWgnome-file-mgr-share
GNOME file manager and support libraries - platform independent files, /usr/share
SUNWgnome-file-mgr
GNOME file manager and support libraries - platform dependent files, /usr filesystem
SUNWgnome-freedb-libs-root
GNOME free CD database access library - platform dependent files, / filesystem
SUNWgnome-freedb-libs-share
GNOME free CD database access library - platform independent files, /usr/share
GNOME free CD database access library - platform dependent files, /usr filesystem
SUNWgnome-fun-applets-root
GNOME panel applets - amusements - platform dependent files, / filesystem
SUNWgnome-fun-applets-share
GNOME panel applets - amusements - platform independent files, /usr/share
GNOME panel applets - amusements - platform dependent files, /usr filesystem
SUNWgnome-games-root
GNOME games - platform dependent files, / filesystem
SUNWgnome-games-share
GNOME games - platform independent files, /usr/share
SUNWgnome-games
GNOME games
SUNWgnome-help-db
GNOME help data base - /var filesystem
SUNWgnome-help-viewer-share
GNOME help system - platform independent files, /usr/share
GNOME help system - platform dependent files, /usr filesystem
SUNWgnome-hex-editor-root
GNOME hex editor - platform dependent files, / filesystem
SUNWgnome-hex-editor-share
GNOME hex editor - platform dependent files, /usr filesystem
SUNWgnome-image-viewer-root
GNOME image viewer - platform dependent files, / filesystem
SUNWgnome-image-viewer-share
GNOME image viewer - platform independent files, /usr/share
GNOME image viewer - platform dependent files, /usr filesystem
SUNWgnome-intranet-applets-root
GNOME panel applets - intranet
SUNWgnome-intranet-applets-share
GNOME panel applets - intranet - platform independent files, /usr/share
SUNWgnome-libs-devel-share
GNOME libraries - developer files - platform independent, /usr/share
SUNWgnome-libs-root
GNOME libraries - platform dependent files, / filesystem
SUNWgnome-libs-share
GNOME libraries - platform independent files, /usr/share
SUNWgnome-libs
GNOME libraries - platform dependent files, /usr filesystem
SUNWgnome-mm-applets-root
GNOME panel applets - multimedia - platform dependent files, / filesystem
SUNWgnome-mm-applets-share
GNOME panel applets - multimedia - platform independent files, /usr/share
GNOME panel applets - multimedia - platform dependent files, /usr filesystem
SUNWgnome-panel-devel-share
GNOME panel and support libraries - developer files - platform independent, /usr/share
SUNWgnome-panel-root
GNOME panel and support libraries - platform dependent files, / filesystem
SUNWgnome-panel-share
GNOME panel and support libraries - platform independent files, /usr/share
SUNWgnome-panel
GNOME panel and support libraries - platform dependent files, /usr filesystem
SUNWgnome-perf-meter-root
GNOME performance meter - platform dependent files, / filesystem
SUNWgnome-perf-meter-share
GNOME performance meter - platform independent files, /usr/share
GNOME performance meter - platform dependent files, /usr filesystem
SUNWgnome-print-devel
GNOME printing technology - developer files
SUNWgnome-print-root
GNOME printing technology - platform dependent files, / filesystem
SUNWgnome-print-share
GNOME printing technology - platform independent files, /usr/share
SUNWgnome-print
GNOME printing technology - platform dependent files, /usr filesystem
SUNWgnome-ps-viewer-root
GNOME post script viewer - platform dependent files, / filesystem
SUNWgnome-ps-viewer-share
GNOME post script viewer - platform independent files, /usr/share
SUNWgnome-ps-viewer
GNOME postscript viewer - platform dependent files, /usr filesystem
SUNWgnome-removable-media-share
GNOME removable media support - platform independent files, /usr/share
GNOME removable media support - platform dependent files, /usr filesystem
SUNWgnome-search-tool-share
GNOME file search tool - platform independent files, /usr/share
GNOME file search tool - platform dependent files, /usr filesystem
SUNWgnome-session-root
GNOME session manager - platform dependent files, / filesystem
SUNWgnome-session-share
GNOME session manager - platform independent files, /usr/share
SUNWgnome-session
GNOME session manager - platform dependent files, /usr filesystem
SUNWgnome-sound-recorder-root
GNOME sound recording utilities - platform dependent files, / filesystem
SUNWgnome-sound-recorder-share
GNOME sound recording utilities - platform independent files, /usr/share
GNOME sound recording utilities - platform dependent files, /usr filesystem
SUNWgnome-terminal-root
GNOME terminal emulator - platform dependent files, / filesystem
SUNWgnome-terminal-share
GNOME terminal emulator - platform independent files, /usr/share
SUNWgnome-terminal
GNOME terminal emulator - platform dependent files, /usr filesystem
SUNWgnome-text-editor-root
GNOME text editor - platform dependent files, / filesystem
SUNWgnome-text-editor-share
GNOME text editor - platform independent files, /usr/share
GNOME text editor - platform dependent files, /usr filesystem
SUNWgnome-themes-share
GNOME themes and support libraries - platform independent files, /usr/share
SUNWgnome-themes
GNOME themes and support libraries - platform dependent files, /usr filesystem
SUNWgnome-ui-designer-share
GNOME GUI wysiwyg designer - platform independent files, /usr/share
GNOME GUI wysiwyg designer - platform dependent files, /usr filesystem
SUNWgnome-user-docs
GNOME user documentation - platform independent files, /usr/share
SUNWgnome-utility-applets-root
GNOME panel applets - utility - root files
SUNWgnome-utility-applets-share
GNOME panel applets - utility - platform independent files, /usr/share
GNOME panel applets - utility - platform dependent files, /usr filesystem
SUNWgnome-vfs-devel-share
GNOME Virtual File System Framework and application/MIME type registry - developer files - platform independent, /usr/share
SUNWgnome-vfs-devel
SUNWgnome-vfs-root
GNOME Virtual File System Framework and application/MIME type registry - platform dependent files, / filesystem
SUNWgnome-vfs-share
GNOME Virtual File System Framework and application/MIME type registry - platform independent files, /usr/share
SUNWgnome-vfs
GNOME Virtual File System Framework and application/MIME type registry - platform dependent files, /usr filesystem
SUNWgnome-wm-root
GNOME window manager - platform dependent files, / filesystem
SUNWgnome-wm-share
GNOME window manager - platform independent files, /usr/share
SUNWgnome-wm
GNOME window manager - platform dependent files, /usr filesystem
SUNWgnome-xml-root
GNOME XML catalogs - platform dependent files, / filesystem
SUNWgnome-xml-share
GNOME XML stylesheets - platform independent files, /usr/share
SUNWgpch
The GNU Patch utility
SUNWgscr
GNU Ghostscript
SUNWgsdhx
GSS-API 64-bit mechanism libraries for NIS+ extended Diffie-Hellman
SUNWgsfot
GNU Ghostscript Fonts (Other)
SUNWgsfst
GNU Ghostscript Fonts (Standard)
SUNWgss
Generic Security Service Application Program Interface, Version 2 - user
SUNWgssc
Generic Security Service Application Program Interface, Version 2 - config
SUNWgssdh
GSS-API mechanism libraries for NIS+ extended Diffie-Hellman
SUNWgssk
Generic Security Service Application Program Interface, Version 2 - kernel
SUNWgsskx
Generic Security Service Application Program Interface, Version 2 - kernel (64-bit)
SUNWgssx
Generic Security Service Application Program Interface, Version 2 - user (64-bit)
SUNWgtar
GNU tar - A utility used to store, backup, and transport files (gtar)
SUNWgzip
The GNU Zip (gzip) compression utility
SUNWhea
SunOS C/C++ header files for general development of software
SUNWhiu8
Traditional Chinese iconv modules for UTF-8
SUNWhiu8x
Traditional Chinese (EUC) iconv modules for UTF-8 (64-bit)
SUNWhmd
SunSwiftTM Adapter Drivers
SUNWhmdu
SunSwift Adapter Headers
SUNWhmdx
SunSwift Adapter Drivers (64-bit)
SUNWhpijs
hpijs - HP InkJet Server 1.4.1
SUNWi13rf
X11 fonts for ISO-8859-13 character set (required fonts)
SUNWi15rf
X11 fonts for ISO-8859-15 character set (required fonts)
SUNWi1of
ISO-8859-1 (Latin-1) Optional Fonts
SUNWi2cr
Device drivers for I2C devices, (Root, 32-bit)
SUNWi2cx
Device drivers for I2C devices, (Root, 64-bit)
SUNWi2rf
X11 fonts for ISO-8859-2 character set (required fonts)
SUNWi4rf
X11 fonts for ISO-8859-4 character set (required fonts)
SUNWi5rf
X11 fonts for ISO-8859-5 character set (required fonts)
SUNWi7rf
X11 fonts for ISO-8859-7 character set (required fonts)
SUNWi8rf
X11 fonts for iso8859-8 character set (required fonts)
SUNWi9rf
X11 fonts for ISO-8859-9 character set (required fonts)
SUNWicu
International Components for Unicode User Files
SUNWicud
International Components for Unicode Developer Files
SUNWicux
International Components for Unicode User Files (64-bit)
SUNWidecr
IDE device drivers updated for UltraAX
SUNWidecx
IDE device drivers - 64bit, updated for UltraAX
SUNWider
IDE Device Driver, (Root)
SUNWidn
Inter-Domain Network Modules for Sun EnterpriseTM 10000
SUNWidnd
Internationalized Domain Name Support Developer Files
SUNWidnl
Internationalized Domain Name Support Library Files
SUNWidnlx
Internationalized Domain Name Support Library Files (64-bit)
SUNWidnx
Inter-Domain Network Modules for Sun Enterprise 10000 (64-bit)
SUNWifb
Device driver for the PCI Bus Sun Expert3D (IFB) graphics accelerator
SUNWifbcf
Configuration utility for the PCI Bus Sun Expert3D (IFB) graphics accelerator
SUNWifbr
Boot-time device initialization support for the PCI Bus Sun Expert3D (IFB) graphics accelerator
SUNWifbw
X server loadable module for the PCI Bus Sun Expert3D (IFB) graphics accelerator
SUNWifbx
Device driver for the PCI Bus Sun Expert3D (IFB) graphics accelerator (64-bit)
SUNWifp
Sun FC-AL Device Driver For QLogic Fibre Channel Family
SUNWifph
SunOS Header Files For QLogic FC-AL Family
SUNWifpx
Sun FC-AL Device Driver For QLogic Fibre Channel Family (64-bit)
SUNWigsr
Kernel device driver (32-bit) for the IGS graphics card
SUNWigsu
OpenWindow DDX Driver for the IGS graphics card
SUNWigsuc
OpenWindow DDX igsconfig for the IGS graphics card
SUNWigsud
OpenWindow DDX headers and man pages for the IGS graphics card
SUNWigsx
Kernel 64-bit device driver for the IGS graphics card
SUNWimagick
ImageMagick - Image Manipulation Utilities and Libraries 5.4.7
SUNWinamd
Internet Domain Name Server
SUNWiniu8
Indic UTF-8 iconv modules for UTF-8
SUNWiniu8x
Indic UTF-8 iconv modules for UTF-8 (64-bit)
SUNWinst
Sun installation software
SUNWipc
utilities to monitor or remove messages, semaphores, or shared memory for interprocess communication
SUNWippcore
Internet Print Protocol (IPP) encoding/decoding/operation support
SUNWipplr
Internet Printing Protoco l(IPP) Apache configuration for service module
SUNWipplu
Internet Printing Protocol (IPP) Apache module for listening service
SUNWiqdoc
Sun ONE Message Queue Javadoc and Examples
SUNWiqfs
Sun ONE Message Queue JNDI FS Provider
SUNWiqjx
Sun ONE Message Queue JAXM Client Runtime Package
SUNWiqr
Sun ONE Message Queue Root Package
SUNWiqu
Sun ONE Message Queue /usr Package
SUNWiquc
Sun ONE Message Queue Client Runtime Package
SUNWiqum
Sun ONE Message Queue JMS/SOAP Msg Transformer Runtime
SUNWiscr
Sun Internal Smart Card Reader I OCF Card Terminal Driver
SUNWiscrx
Sun Internal Smart Card Reader I OCF Card Terminal Driver (64-bit)
SUNWislcc
XSH4 conversion for Eastern European locales
SUNWislcx
64-bit iconv conversion for Eastern European locales
SUNWisolc
XSH4 conversion for ISO Latin character sets
SUNWisolx
64-bit iconv conversion for ISO Latin character sets
SUNWj2dem
Demonstration applications and applets
SUNWj2man
man pages
SUNWj2pi
This package contains configuration files for Java Plug-in 1.2.2
SUNWj2rt
Java virtual machine and core class libraries
SUNWj3cfg
Post configuration for SUNWj3rt package
SUNWj3dev
Tools and utilities including javac, jdb, javadoc, rmiregistry
SUNWj3dmo
SUNWj3dvx
Tools and utilities including javac, jdb, javadoc, rmiregistry (64 bit)
SUNWj3irt
JDKTM 1.4 I18N run time environment
SUNWj3man
man pages
SUNWj3rt
SUNWj3rtx
Java virtual machine and core class libraries (64 bit)
SUNWjaf
Java Activation Framework
SUNWjaxp
Java API for XML Parsing 1.2
SUNWjcom
Java Communications API for Smart Card support - Java and Native Code
SUNWjcomx
Java Communications API for Smart Card support - Native Code (64-bit)
SUNWjfbcf
Configuration software for the PCI Bus Sun XVR-1200 graphics accelerator (64-bit)
SUNWjfbmn
Manual pages for the PCI Bus Sun XVR-1200 and XVR-600 graphics accelerators
SUNWjfbr
Boot-time device initialization support for the PCI Bus Sun XVR-1200 graphics accelerator (64-bit)
SUNWjfbw
X server loadable module for the PCI Bus Sun XVR-1200 graphics accelerator (64-bit)
SUNWjfbx
Device driver for the PCI Bus Sun XVR-1200 graphics accelerator (64-bit)
SUNWjhdem
JavaHelpTM graphical help demos
SUNWjhdev
A pre-defined minimal software configuration consisting of the minimum required software for a standalone, non-networked workstation.
SUNWjhdoc
JavaHelp graphical help documentation
SUNWjhrt
JavaHelp graphical help runtime
SUNWjib
Dallas Semiconductor serial iButton OCF Card Terminal Driver
SUNWjiu8
Japanese iconv modules for conversion between UTF-8 and other Japanese codesets
SUNWjiu8x
Japanese 64-bit iconv modules for conversion between UTF-8 and other Japanese codesets
SUNWjmail
Java Mail Runtime
SUNWjmfp
JMF player
SUNWjpg
The Independent JPEG Groups JPEG software
SUNWjpgx
jpeg - The Independent JPEG Groups JPEG software (64-bit)
SUNWjsnmp
Solaris Java SNMP API
SUNWjss
Network Security Services for Java (JSS)
SUNWjssx
Network Security Services for Java (JSS) (64-bit)
SUNWjxmft
Japanese {Sun,HG,RICOH} Gothic Medium Bitmap Fonts
SUNWkcslx
Kodak Color Management SystemTM Runtime Library for 64 bit OS
SUNWkcspf
Kodak Color Management System Runtime
SUNWkcspg
Kodak Color Management System Runtime Demos
SUNWkcspx
Kodak Color Management System Runtime Demos for 64 bit
SUNWkcsrl
Kodak Color Management System Runtime Library Support
SUNWkcsrr
Kodak Color Management System Runtime Profiles
SUNWkcsrt
SUNWkcsrx
Kodak Color Management System Runtime for 64 bit OS
SUNWkdcr
Kerberos V5 KDC (root)
SUNWkdcu
Kerberos V5 Master KDC (user)
SUNWkey
Configuration tables that specify keyboard attributes such as localized meanings for individual keys
SUNWkfb.u
Sun XVR-2500 Graphics System Software/Device Driver (64–bit)
SUNWkfbcf
Sun XVR-2500 Graphics Configuration Software (64–bit)
SUNWkfbr
Sun XVR-2500 Graphics System Software (Root) (64–bit)
SUNWkfbw
Sun XVR-2500 Graphics Window System Support (64–bit)
SUNWkiu8
Korean UTF-8 iconv modules for UTF-8
SUNWkiu8x
Korean (UTF-8) iconv modules for UTF-8 (64-bit)
SUNWkmp2r
PS/2 Keyboard and Mouse Device Drivers (Root) (32-bit)
SUNWkmp2x
PS/2 Keyboard and Mouse Device Drivers (Root) (64-bit)
SUNWkoi8f
X11 fonts for KOI8-R character set
SUNWkrbr
Kerberos version 5 support (Root)
SUNWkrbu
Kerberos version 5 support (Usr)
SUNWkrbux
Kerberos version 5 support (Usr) (64-bit)
SUNWkvm
SUNWkvmx
SUNWkxmft
Korean UTF-8 X Windows Platform Required Fonts
SUNWladm
Locale Administrator
SUNWlccom
localization common files
SUNWlcl
Locale Conversion Library
SUNWlclx
Locale Conversion Library (64-bit)
SUNWless
The GNU pager (less)
SUNWlibC
Sun Workshop Compilers Bundled libC
SUNWlibCf
SunSoftTM WorkShop Bundled libC (cfront version)
SUNWlibCx
Sun WorkshopTM Bundled 64-bit libC
SUNWlibm
ForteTM Developer Bundled libm
SUNWlibms
Forte Developer Bundled shared libm
SUNWlibpopt-64
command line parsing library (64-bit) - platform dependent files, /usr filesystem
SUNWlibpopt-share
command line parsing library - platform independent files, /usr/share
SUNWlibpopt
SUNWllc
LLC2 driver implementing IEEE 802.2 Logical Link Control 2 service
SUNWllcr
The configuration and startup files for llc2 driver
SUNWllcx
64-bit kernel device drivers implementing IEEE 802.2 Logical Link Control 2 service
SUNWlldap
Ldap libraries in for software development of dynamically linked executables
SUNWlmsx
Forte Developer Bundled 64-bit shared libm
SUNWlmx
Forte Developer Bundled misc. 64-bit libm files
SUNWloc
localization utilities and C locale (POSIX default) definitions
SUNWlocx
localization utilities and C locale (POSIX default) definitions (64-bit)
SUNWlpmsg
ToolTalkTM programs for passing printer alerts.
SUNWlur
Live Upgrade (root)
SUNWluu
Live Upgrade (usr)
SUNWluxd
Sun Enterprise Network ArrayTM sf Device Driver
SUNWluxdx
Sun Enterprise Network Array sf Device Driver (64-bit)
SUNWluxl
Sun Enterprise Network Array socal Device Driver
SUNWluxlx
Sun Enterprise Network Array socal Device Driver (64-bit)
SUNWluxop
Sun Enterprise Network Array firmware and utilities
SUNWluxox
Sun Enterprise Network Array libraries (64-bit)
SUNWlvma
Solaris Volume Management APIs
SUNWlvmg
Solaris Volume Management Application
SUNWlvmr
Solaris Volume Management (root)
SUNWlxml
The XML library (libxml2-2.4.23)
SUNWlxmlx
The XML library (libxml2-2.4.23, 64-bit)
SUNWlxsl
The XSLT library (libxslt-1.0.19)
SUNWlxslx
The XSLT library (libxslt-1.0.19, 64-bit)
SUNWm64
Device driver for the M64 graphics accelerator
SUNWm64cf
Configuration utility for the PCI Bus M64 graphics accelerator
SUNWm64w
X server loadable module for the M64 graphics accelerator
SUNWm64x
Device driver for the M64 graphics accelerator (64-bit)
SUNWm64xr
Extended configuration for Xclaim, Charger and Rage Pro graphics cards
SUNWman
System Reference Manual Pages
SUNWmc
This package contains the client and server components of the Solaris Management Console
SUNWmcc
This package contains the client components of the Solaris Management Console
SUNWmccom
This package contains the common components of the Solaris Management Console
SUNWmcdev
This package contains the software development kit for the Solaris Management Console
SUNWmcex
This package contains example applications for the Solaris Management Console.
SUNWmdar
Solaris Volume Manager Assistant (Root)
SUNWmdau
Solaris Volume Manager Assistant (Usr)
SUNWmdb
Modular Debugger (MDB)
SUNWmdbdm
Modular Debugger (MDB) demonstration modules and source code
SUNWmdbx
Modular Debugger (MDB) (64-bit)
SUNWmddr
reconfiguration coordination manager module for SVM
SUNWmdi
mpxio module and scsi_vhci device driver
SUNWmdix
mpxio module and scsi_vhci device driver (64-bit)
SUNWmdr
Solaris Volume Manager driver
SUNWmdu
Solaris Volume Manager commands
SUNWmdx
Solaris Volume Manager drivers (64-bit)
SUNWmfdev
Motif UIL compiler
SUNWmfman
CDE Motif Manuals
SUNWmfrun
Motif 2.1 libraries, headers, xmbind and bindings
SUNWmga
Solaris Management Applications
SUNWmgapp
WBEM Management Applications
SUNWmibii
Solstice Enterprise Agents 1.0.3 snmp daemon
SUNWmipr
Mobile-IP configuration and startup scripts
SUNWmipu
Mobile-IP daemon and utilities
SUNWmkcd
CD creation utilities
SUNWmp
MP Print Filter
SUNWncar
core components to enable the network cache and accelerator
SUNWncarx
core components to enable the network cache and accelerator (64-bit)
SUNWncau
SUNWncaux
SUNWncft
NcFTP ncftp - File Transfer Protocol (FTP)
SUNWnfb
Sun XVR-300 Graphics System Software/Device Driver (64–bit)
SUNWnfbcf
Sun XVR-300 Graphics Configuration Software (64–bit)
SUNWnfbw
Sun XVR-300 Graphics Window System Support (64–bit)
SUNWnfscr
Network File System (NFS) client support (Root)
SUNWnfscu
Network File System (NFS) client support (Usr)
SUNWnfscx
Network File System (NFS) client support (Root) (64-bit)
SUNWnfssr
Network File System (NFS) server support (Root)
SUNWnfssu
Network File System (NFS) server support (Usr)
SUNWnfssx
Network File System (NFS) server support (Root) (64-bit)
SUNWnisr
configuration files and directories for the Network Information System (NIS and NIS+)
SUNWnisu
utilities for the Network Information System (NIS and NIS+)
SUNWnsb
NetscapeTM 7 for Solaris
SUNWnsm
Netscape 7 for Solaris
SUNWnspsm
SUNWnsxp
SUNWntpr
Network Time Protocol v3, NTP Daemon and Utilities (xntpd)
SUNWntpu
SUNWocf
Open Card Framework - core libraries and utilities
SUNWocfd
Open Card Framework - Javadoc for SCF Java APIs
SUNWocfh
Open Card Framework - header files
SUNWocfr
Open Card Framework - configuration files
SUNWocfx
Open Card Framework (OCF) - 64-bit core libraries
SUNWolrte
OPEN LOOK toolkits runtime environment
SUNWopl5m
Perl 5.005_03 Reference Manual Pages
SUNWopl5p
POD documentation for Perl 5 programming language
SUNWopl5u
Perl 5.005_03 programming language
SUNWosdem
Source code to demonstrate the use of OS interfaces: ELF
SUNWowbcp
Support files, programs, and libraries for OpenWindows Binary Compatibility
SUNWpamsc
Pluggable Authentication Module for Smart Card Authentication
SUNWpamsx
Pluggable Authentication Module for Smart Card Authentication (64-bit)
SUNWpapi
Free Standards Group Open Printing API, Draft v0.9
SUNWpcelx
3COM EtherLink III PCMCIA Ethernet Driver
SUNWpcelxx
3COM EtherLink III PCMCIA Ethernet Driver (64-bit)
SUNWpcmci
kernel modules and start-up files for PCMCIA card services
SUNWpcmcu
daemon providing PCMCIA card services
SUNWpcmcx
64-bit kernel modules for PCMCIA card services
SUNWpcmem
PCMCIA memory card driver
SUNWpcmemx
PCMCIA memory card driver (64-bit)
SUNWpcr
client configuration files and utilities for the print service
SUNWpcser
PCMCIA serial card driver
SUNWpcserx
PCMCIA serial card driver (64-bit)
SUNWpcu
SUNWpd
Drivers for SPARC platforms with the PCI bus
SUNWpdas
Tools to synchronize desktop applications with the Palm Pilot PDA
SUNWpdu
SunOS C/C++ header files for development of software for the PCI bus on SPARC platforms.
SUNWpdx
64-bit Drivers for SPARC platforms with the PCI bus
SUNWpfbcf
Configuration utility for the PCI Bus Sun XVR-100 graphics accelerator (64-bit)
SUNWpfbw
X server loadable module for the PCT Bus Sun XVR-100 graphics accelerator (64-bit)
SUNWpfbx
Device driver for the PCI Bus Sun XVR-100 graphics accelerator (64-bit)
SUNWphx
Solaris interface for phx
SUNWphxx
Solaris interface for phx (64 bit)
SUNWpiclh
PICL Header Files
SUNWpiclr
PICL Framework init scripts
SUNWpiclu
PICL Daemon, Libraries, prtpicl client and plug-in modules
SUNWpiclx
PICL Libraries for clients (64-bit)
SUNWpl5m
Perl 5.6.1 Reference Manual Pages
SUNWpl5p
POD documentation for Perl 5.6.1 programming language
SUNWpl5u
Perl 5.6.1 programming language (core)
SUNWpl5v
Perl 5.6.1 programming language (non-core)
SUNWplowr
Root pkg which delivers script for upgrades.
SUNWpmgr
Solaris Patch Management Applications
SUNWpmowm
Power Management OW Utilities Man Pages
SUNWpmowr
Power Management OW Utilities, (Root)
SUNWpmowu
SUNWpmr
Power Management config file and rc script
SUNWpmu
Power Management binaries
SUNWpmux
Power Management binaries (64-bit)
SUNWpng
Portable Network Graphics Reference Library
SUNWpngx
PNG - Portable Network Graphics library (64-bit)
SUNWpool
core software for resource pools
SUNWpoolx
core software for resource pools (64-bit)
SUNWppm
Graphical tool for managing printers under Solaris.
SUNWpppd
Device drivers implementing point-to-point protocol (PPP)
SUNWpppdr
Configuration files for Solaris Point-to-Point Protocol (PPP)
SUNWpppdt
Extensions implementing PPP tunneling protocols
SUNWpppdu
Daemon and utilities for Point-to-Point Protocol (PPP)
SUNWpppdx
64-bit device drivers implementing point-to-point protocol (PPP)
SUNWpppg
Optional GNU utilities for use with PPP
SUNWpr
SUNWprx
Netscape Portable Runtime Interface (64-bit)
SUNWpsdpr
PCMCIA ATA card driver
SUNWpsdprx
PCMCIA ATA card driver (64-bit)
SUNWpsf
SUNWpsm-lpd
Client side support for communicating with RFC-1179 based print servers
SUNWpsr
configuration and start-up files for the print service
SUNWpstl
Apptrace processor specific shared objects
SUNWpstlx
Apptrace processor specific shared objects (64-bit)
SUNWpsu
SUNWpsutils
psutils - PostScript utilities p 17
SUNWqfed
Sun Quad FastEthernetTM PCI/SBus Adapter 32Bit Driver
SUNWqfedu
Sun Quad FastEthernet PCI/SBus Adapter Headers
SUNWqfedx
Sun Quad FastEthernet PCI/SBus Adapter 64Bit Driver
SUNWqlc
Qlogic ISP 2200/2202 Fibre Channel Device Driver
SUNWqlcx
Qlogic ISP 2200/2202 Fibre Channel Device Driver (64-bit)
SUNWqos
Solaris IP Quality of Service (Root)
SUNWqosu
Solaris IP Quality of Service (Usr)
SUNWqosx
Solaris IP Quality of Service (64-bit)
SUNWrcapr
Solaris Resource Capping Daemon (Root)
SUNWrcapu
Solaris Resource Capping Daemon (Usr)
SUNWrcmdc
Remote Network Client Commands (rsh, rlogin, rcp, rsh, ...)
SUNWrcmdr
Remote Network Server Commands (Root)
SUNWrcmds
Remote Network Server Commands (includes finger, talk, rwho commands)
SUNWrmodu
Realmode Modules, (Usr)
SUNWrmui
Resource Management for Solaris
SUNWrmwbr
SUNWrmwbu
SUNWrmwbx
SUNWroute
Network Routing daemons/commands (Usr)
SUNWrpm
Utilities for processing RPM archives
SUNWrsg
GSS-API services for ONC RPC
SUNWrsgk
kernel GSS-API services for ONC RPC
SUNWrsgx
GSS-API services for ONC RPC (64-bit)
SUNWrsm
Remote Shared Memory API Library, Driver
SUNWrsmo
Support for network specific implementations of RSMPI
SUNWrsmox
Support for network specific implementations of RSMPI (64-bit)
SUNWrsmx
Remote Shared Memory API Library, Driver (64-bit)
SUNWrtvc
Device driver for the SunVideoTM real-time video capture and compression card
SUNWrtvcl
XIL loadable pipelines for SunVideo capture and compression
SUNWrtvcu
Header files, and examples for SunVideo capture and compression
SUNWrtvcx
Device driver for the SunVideo real-time video capture and compression card (64-bit)
SUNWsacom
Solstice Enterprise AgentsTM 1.0.3 files for root file system
SUNWsadmi
Solstice Enterprise Agents 1.0.3 Desktop Management Interface
SUNWsadml
Solstice launcher and associated libraries.
SUNWsadmx
Solstice Enterprise Agents 1.0.3 Desktop Management Interface Libraries (64-bit)
SUNWsasnm
Solstice Enterprise Agents 1.0.3 Simple Network Management Protocol
SUNWsasnx
Solstice Enterprise Agents 1.0.3 Simple Network Management Protocol Libraries (64-bit)
SUNWscbcp
SPARCompilers Binary Compatibility Libraries
SUNWscgui
Solaris Smart Card Administration - Graphical User Interface component
SUNWsckmr
Init script & links for Sun Fire 15000 Key Management daemon
SUNWsckmu
Key Management daemon for Sun Fire 15000
SUNWsckmx
Key Management Modules for Sun Fire 15000 (64-Bit)
SUNWscmos
SCM Microsystems SmartOS smart card protocol module
SUNWscmsc
Sun SCRI OCF Card Terminal Driver
SUNWscplp
print utilities for user interface and source build compatibility with SunOS 4.x
SUNWscpr
SUNWscpu
SUNWscpux
SUNWses
SCSI Enclosure Services (ses) Device Driver
SUNWsesx
SCSI Enclosure Services (ses) Device Driver (64-bit)
SUNWsfdoc
GNU and open source documentation
SUNWsfdr
Sun Fire 880 DR Daemon
SUNWsfdrr
DR Daemon init script for Sun Fire 880, (Root)
SUNWsfinf
GNU and open source info pages
SUNWsfman
GNU and open source man pages
SUNWsior
SuperIO 307 (plug-n-play) device drivers, (Root) (32-bit)
SUNWsiox
SuperIO 307 (plug-n-play) device drivers, (Root) (64-bit)
SUNWslpr
Root filesystem portion of the Service Location Protocol (SLP) framework. Includes the SLP configuration file and start scripts for the SLP daemon.
SUNWslpu
Usr filesystem portion of the Service Location Protocol (SLP) framework. Included are C and Java developer libraries and a daemon which can act as a directory agent (DA).
SUNWslpx
Service Location Protocol (SLP) 64-bit developer libraries
SUNWsmapi
Software libraries for storage management
SUNWsmbac
samba - A Windows SMB/CIFS fileserver for UNIX (client)
SUNWsmbar
samba - A Windows SMB/CIFS fileserver for UNIX (Root)
SUNWsmbau
samba - A Windows SMB/CIFS fileserver for UNIX (Usr)
SUNWsndmr
sendmail root
SUNWsndmu
sendmail user
SUNWsolnm
Enable Solaris Name in /etc/release file
SUNWspl
Spell Checking Engine - Base Release (English)
SUNWsprot
Solaris Bundled tools
SUNWsprox
Sun Workshop Bundled 64-bit make library
SUNWsra
libraries in archive (ar) format for source build compatibility with SunOS 4.x
SUNWsregu
Solaris User Registration prompts at desktop login for user registration information.
SUNWsrh
SunOS C/C++ header files for source build compatibility with SunOS 4.x
SUNWssad
pln, soc, and ssd kernel device drivers
SUNWssadx
pln, soc, and ssd kernel device drivers (64-bit)
SUNWssaop
administration utilities and firmware for the SPARCstorage Array (SSA)
SUNWsshcu
Secure Shell protocol common Utilities
SUNWsshdr
Secure Shell protocol Server
SUNWsshdu
SUNWsshr
Secure Shell protocol Client and associated Utilities
SUNWsshu
SUNWstcx
I2C Smartcard kernel device driver for SCM STC chip - (64-bit)
SUNWstsf
Standard Type Services Framework
SUNWstsfr
Standard Type Services Framework software configuration (root filesystem components)
SUNWstsfx
Standard Type Services Framework (64-bit)
SUNWsutl
statically linked utilities for system disaster recovery
SUNWswmt
Solaris 2.x Install and Patch Utilities
SUNWsx
Shareable library and header files for SX/CG14 loadable pipeline support
SUNWsxow
X server loadable module for the SX/CG14 graphics accelerator
SUNWsxr
kernel device drivers for the SX video subsystem
SUNWtcatr
Tomcat Servlet/JSP Container (root)
SUNWtcatu
SUNWtcpd
tcpd - access control facility for internet services
SUNWtcsh
Tenex C-shell (tcsh)
SUNWtcx
Device driver for the S24 frame buffer
SUNWtcxow
X server loadable module and configuration utility for the S24 frame buffer
SUNWter
extensive terminfo database entries describing capabilities of terminals and pseudoterminals
SUNWtexi
GNU texinfo (texinfo)
SUNWtftp
Trivial File Transfer Server
SUNWtftpr
Trivial File Transfer Server (Root)
SUNWtiu8
Thai UTF-8 iconv modules for UTF-8
SUNWtiu8x
Thai UTF-8 iconv modules for UTF-8 (64-bit)
SUNWtls
SUNWtlsu
SUNWtlsux
Network Security Services Utilities Programs (64-bit)
SUNWtlsx
Network Security Services (64-bit)
SUNWtltk
ToolTalk binaries and shared libraries needed for Common Desktop Environment (CDE), OpenWindows, and all ToolTalk clients
SUNWtltkd
ToolTalk static library and include files for programmers
SUNWtltkm
ToolTalk manual pages for ToolTalk programmers, OpenWindows users, and Common Desktop Environment (CDE) users
SUNWtltkx
ToolTalk library (64-bit) needed for Common Desktop Environment (CDE), OpenWindows, and all ToolTalk clients
SUNWtnamd
Trivial Name Server (Usr)
SUNWtnamr
Trivial Name Server (Root)
SUNWtnetc
Telnet Command (client)
SUNWtnetd
Telnet Server Deamon (Usr)
SUNWtnetr
Telnet Server Deamon (Root)
SUNWtnfc
utilities needed to enable probe points, in the kernel and in applications, that can generate Trace Normal Format (TNF) records in a trace file
SUNWtnfcx
64-bit utilities needed to enable probe points, in the kernel and in applications, that can generate Trace Normal Format (TNF) records in a trace file
SUNWtnfd
utilities needed by developers using Trace Normal Format (TNF) facilities
SUNWtoo
utilities for software development, including ld, ldd, od, and truss
SUNWtoox
utilities for software development (64-bit)
SUNWtxfnt
Thai X Windows Platform required Fonts Package
SUNWucbt
Apptrace shared objects for UCB compatibility libraries
SUNWucbtx
Apptrace shared objects for UCB compatibility libraries (64-bit)
SUNWudf
Universal Disk Format 1.50 File System, (Usr)
SUNWudfr
SUNWudfrx
Universal Disk Format 1.50 File System (64-bit)
SUNWuiu8
Iconv modules for UTF-8 Locale
SUNWuiu8x
Iconv Modules for UTF-8 Locale (64-bit)
SUNWuium
ICONV Manual pages for UTF-8 Locale
SUNWulcf
UTF-8 Locale Environment Common Files
SUNWulcfx
UTF-8 Locale Environment Common Files (64-bit)
SUNWulocf
UTF-8 Locale Environment OpenWindows Common Files
SUNWusb
USBA (USB framework) and USB Device Drivers
SUNWusbu
USB Headers
SUNWusbx
USBA (USB framework) and USB Device Drivers (64-bit)
SUNWusoc
Sun Universal SOC+ Fibre Channel Device Driver
SUNWusocx
Sun Universal SOC+ Fibre Channel Device Driver (64-bit)
SUNWusx
UltraSPARC CPU Device Driver (64-bit)
SUNWuxfl1
SMCC System FLASH PROM update for SUNW,Ultra-1
SUNWuxfl2
SMCC System FLASH PROM update for SUNW,Ultra-2
SUNWuxfl4
SMCC System FLASH PROM update for SUNW,Ultra-4
SUNWuxfle
SMCC System FLASH PROM update for SUNW,Ultra-Enterprise
SUNWuxflr
Generic components for Sun4u SMCC System FLASH PROM Update
SUNWuxflu
SUNWuxlcf
UTF-8 X Locale Environment Common Files
SUNWuxlcx
UTF-8 X Locale Environment Common Files (64-bit)
SUNWvid
Generic Video Timing Information
SUNWvld
Sun Ethernet Vlan Utility Routines (32-bit)
SUNWvldu
Sun Ethernet Vlan Utility Header files
SUNWvldx
Sun Ethernet Vlan Utility Routines (64-bit)
SUNWvolg
Volume Management Graphical User Interface
SUNWvolr
configuration and start-up files for volume (removable media) management and volfs
SUNWvolu
utilities and a daemon (vold) for volume (removable media) management and volfs
SUNWvolux
Driver for volume (removable media) management (64-bit)
SUNWvygdr
VoyagerTM Drivers and Streams Module
SUNWwbapi
Solaris WBEM API
SUNWwbcor
Solaris WBEM Services (root)
SUNWwbcou
Solaris WBEM Services (usr)
SUNWwbdev
Sun WBEM SDK
SUNWwbdoc
Sun WBEM SDK - Documentation
SUNWwbmc
This package contains the components integrating WBEM and SMC
SUNWwbpro
Solaris WBEM Providers (usr)
SUNWwbsup
Solaris WAN boot support
SUNWwgetr
GNU wget - a utility to retrieve files from the World Wide Web (root components)
SUNWwgetu
GNU wget - a utility to retrieve files from the World Wide Web (Usr)
SUNWwrsax
Library to enable Remote Shared Memory over WCI interface (64-bit)
SUNWwrsdx
DLPI Driver for use with the WCI Remote Shared Memory Driver (64-bit)
SUNWwrsmx
WCI Remote Shared Memory Drivers (64-bit)
SUNWwrsux
Commands and libraries for the wrsm and wrsmd drivers (64-bit)
SUNWwsr2
Solaris Product Registry & Web Start runtime support
SUNWwsrv
Solaris Product Registry Viewer
SUNWxcu4
utilities providing conformance with XCU4 specifications
SUNWxcu4t
XCU4 Compliant Versions of make and sccs utilities
SUNWxi18n
Run time library loaded by libX11.so, and provides input and output capability for internationalized X Window applications.
SUNWxi18x
Run time library loaded by sparcv9/libX11.so, and provides input and output capability for internationalized X Window applications.
SUNWxilcg
XILTM loadable pipelines for the SX/CG14 graphics accelerator
SUNWxildh
XIL Loadable Pipeline Libraries
SUNWxilh
XIL API Header files
SUNWxilow
XIL Deskset Loadable Pipeline Libraries
SUNWxilrl
XIL Runtime Environment
SUNWxilvl
XIL loadable pipelines for all sun4u platforms. Includes loadable pipelines for the UPA Bus Creator graphics accelerator.
SUNWxim
X Input Method server provides different styles of input.
SUNWximx
SUNWxrgrt
JAXR Runtime
SUNWxrpcrt
JAX-RPC Runtime
SUNWxsrt
Soap Runtime
SUNWxwacx
AccessX client program
SUNWxwcft
X Window System optional fonts
SUNWxwcsl
Font support library for Type1/CID fonts.
SUNWxwdem
X Window System demo programs
SUNWxwdim
Graphics files in various formats
SUNWxwdv
kernel device drivers for X Windows System
SUNWxwdvx
64-bit kernel device drivers for X Windows System
SUNWxwdxm
DPS MOTIF library
SUNWxwfa
Font Administration application for Solaris platforms
SUNWxwfnt
X Window System Fonts (required fonts)
SUNWxwfs
X Window System font server
SUNWxwhl
X Window System & Graphics Header links in /usr/include
SUNWxwice
Library and utilities to support the X Window System Inter-Client Exchange (ICE) protocol
SUNWxwicx
X Window System ICE 64-bit library
SUNWxwinc
X Window System include files
SUNWxwkey
X Windows software, PC keytables
SUNWxwman
X Window System online user man pages
SUNWxwmod
Kernel modules used by the Solaris X Window System Server
SUNWxwmox
64-bit Kernel modules for X Windows
SUNWxwoft
SUNWxwopt
X Window System Optional Clients
SUNWxwpft
X Window System Xprt Printer Fonts
SUNWxwpl
Platform specific X server supplementary links
SUNWxwplt
X Window System platform software (server, DPS, extensions, Xlib, required & common clients)
SUNWxwplx
X Window System 64-bit library software
SUNWxwpmn
X Window System online programmers man pages
SUNWxwpsr
This package contains X server modules optimized for SUN4u platform. This package is not required for non-SUN4u platforms; but installing this package will not affect the working of server on non-SUN4u platforms.
SUNWxwrtl
X Window System & Graphics runtime library links
SUNWxwrtx
X Window System 64-bit Library Links in /usr/lib/sparcv9
SUNWxwslb
X Window System static and lint libraries for programmers.
SUNWxwslx
X Window System 64-bit lint libraries for programmers.
SUNWxwsrc
X Window System example source code for programmers.
SUNWxwsrv
X Window System Xvfb & Xnest Virtual Display Servers
SUNWxwsvr
Screen Saver/Locker for X Window System
SUNWxwxft
X Window System Xft (X Freetype) Library
SUNWxwxftx
SUNWxwxst
X Window System XST extension
SUNWxwxstx
X Window System XST extension (64-bit)
SUNWypr
NIS Server for Solaris 2.6 and up
SUNWypu
SUNWzip
The Info-Zip (zip) compression utility
SUNWzlib
The Zip compression library
SUNWzlibx
The Zip compression library (64-bit)
SUNWzsh
Z shell (zsh)
SUNWzuluc
Configuration software for the Sun XVR-4000 graphics accelerator (64-bit)
SUNWzulur
Boot-time device initialization support for the Sun XVR-4000 graphics accelerator (64-bit)
SUNWzuluw
X server loadable module for the Sun XVR-4000 graphics accelerator (64-bit)
SUNWzulux
Device driver for the Sun XVR-4000 graphics accelerator (64-bit)
TSBWvplr
Toshiba platform links
TSBWvplu
Toshiba usr/platform links
TSIpgx
Device driver for PGX32 (Raptor GFX) graphics accelerator
TSIpgxw
X Server loadable module for PGX32 (Raptor GFX) graphics accelerator
TSIpgxx
Device driver for PGX32 (Raptor GFX) graphics accelerator (64-bit)
