The cascading service proposed in the com.sun.jdmk.remote.cascading package is based on a simple MBean class, the CascadingServiceMBean.
The CascadingServiceMBean provides methods that make it possible to mount MBeans from a source MBean server in a target MBean server under a target domain path. Usually the target MBean server is the MBean server in which the CascadingService is registered.
There should be only one CascadingServiceMBean per target MBean server.
The CascadingServiceMBean.mount method mounts a partial view of a source MBean server known by its JMXServiceURL in the target MBean server of the CascadingServiceMBean.
The CascadingServiceMBean.unmount method cancels a previous mount operation. The unmount operation will close the connection that was opened by the mount operation.
The default CascadingService implementation provided in the Java DMK 5.1 relies on proxy-based cascading and implements the mount operation by instantiating a ProxyCascadingAgent behind the scenes. Although the ProxyCascadingAgent offers a public API, you should not use it directly. Applications should use the CascadingServiceMBean instead.
CascadingServiceMBeans are also notification emitters, which emit notifications when mountpoints are unmounted, as a result of a an unmount operation, or because the underlying connection with the source MBean server has been closed or failed.
