The JMXMP connector negotiates security parameters during the initial handshake of a connection. In particular, the JMXMP connector can negotiate that the connection use transport layer security (TLS), which is basically the same as SSL 3.0. The server can require that only connections with TLS are accepted.
The SASL mechanisms DIGEST-MD5 and GSSAPI also provide connection privacy. See 2.6.1.2 Client Authentication in the JMXMP connector.
Privacy can be assured for the RMI connector by using an RMI socket factory to cause connections to be created using TLS. Java DMK 5.1 includes a socket factory that does this. The connector server imposes the socket factory, which is serialized into client stubs so that all clients automatically use it.
