The Relation Service is used to record relationships between MBeans in an MBean server. The Relation Service is itself an MBean. More than one instance of a Relation Service MBean can be registered in an MBean server.
A relation type defines a relationship between MBeans. A relation type contains roles that the MBeans play in the relationship. Usually, there are at least two roles in a relation type.
A relation is a named instance of a relation type, where specific MBeans appear in the roles, represented by their object names.
For example, suppose Module MBeans represent the modules within an application. A DependsOn relation type could express the relationship that some modules depend on others, which could be used to determine the order in which the modules are started or stopped. The DependsOn relation type would have two roles, dependent and dependedOn.
Every role is typed, meaning that an MBean that appears in that role must be an instance of the role's type. In the DependsOn example, both roles would be of type Module.
Every role has a cardinality, which provides lower and upper bounds on the number of MBeans that can appear in that role in a given relation instance. Usually, the lower and upper bounds are both 1, with exactly one MBean appearing in the role. The cardinality only limits the number of MBeans in the role per relation instance. The same MBean can appear in the same role in any number of instances of a relation type. In the DependsOn example, a given module can depend on many other modules, and be depended on by many others, but any given relation instance links exactly one dependent module with exactly one dependedOn module.
A relation type can be created explicitly, as an object implementing the RelationType interface, typically a RelationTypeSupport. Alternatively, a relation type can be created implicitly using the Relation Service's createRelationType method. A relation instance can be created explicitly, as an object implementing the Relation interface, typically a RelationSupport. A RelationSupport is itself a valid MBean, so it can be registered in the MBean server, though this is not required. Alternatively, a relation instance can be created implicitly using the Relation Service's createRelation method.
Through the relation service, users can create relation types and then create, access, and delete instances of a relation. All MBeans are referenced by their object name, so that a relation can be accessed from a remote application. An MBean does not need to know what relations it participates in. New kinds of relations can be added to an agent without having to modify the code of the MBeans that they link.
The relation service provides query mechanisms to retrieve MBeans that are related to each other. The relation service is notified when MBeans in a relation are unregistered, and it verifies that any relation involving that MBean still has the required cardinality.
The relation service can represent a relation instance either internally or externally. If the user defines a relation instance through the API of the relation service, the relation is represented by internal structures that are not accessible to the user. This is the simplest way to define relations, because the relation service handles all coherence issues through its internal structures.
A relation instance can also be a separate MBean object that fulfills certain requirements. The user instantiates and registers these MBeans, ensures that they represent a coherent relationship, and places these MBeans under the control of the relation service. This process places the responsibility of maintaining coherency on the user, but external relations have certain advantages. They can implement operations on a relation instance. Because external relations are MBeans, these extended operations are available to remote management applications.
