Solaris Bandwidth Manager 1.6 System Administration Guide
Using a Solstice Site or Domain Manager Console
The files ba_mib.oid and ba_mib.schema in the /opt/SUNWconn/ba/snmp directory allow you to query the Solaris Bandwidth Manager SNMP agent from a Solstice Site or Domain Manager console. Copy them to the agents directory (by default /opt/SUNWconn/snm/agents) on the management station. Then rebuild the OID database using the command build_oid. The file ba_mib.traps in the /opt/SUNWconn/ba/snmp directory is used to map the trap numbers to an ASCII string. Append it to the trap file (by default /var/opt/SUNWconn/snm/snmp.traps). See the Solstice Site and Domain Manager documentation for more information about this process.
