There are some restrictions on what can be changed dynamically:
You cannot change from IP-transparent to non-transparent mode, or from non-transparent to IP-transparent mode.
If you add an interface, you may have to reboot your system. For more information, see "Configuration Files and Directories ".
When the policy agent is running in lightweight mode, it is not possible to restart it.
