Sun Java System Portal Server 7.1 Administration Guide
ProcedureTo Edit a Site Definition
  1. Log in to the Portal Server management console.
  2. Select Search Servers from the menu bar, then select a search server.
  3. Click Robot from the menu bar, then Sites.
  4. Click the name of the site you want to modify.
    The Edit Site dialog appears.
  5. Modify the configuration attributes as necessary.
    For more information about the attributes, see Sites in Sun Java System Portal Server 7.1 Technical Reference
  6. Click OK to record the changes.
