This appendix provides cabling diagrams for installation and maintenance of Fibre Channel JBOD storage devices. It contains the following sections:
Figure A–1 shows a sample storage array configuration.
You must use FC switches when you install storage arrays in a partner-group configuration. If you want to create a storage area network (SAN) by using two FC switches and Sun SAN software, see SAN Solutions in a Sun Cluster Environment in Sun Cluster 3.1 - 3.2 Hardware Administration Manual for Solaris OS for more information.
For more information about how to cable and configure storage arrays, see the Sun StorEdge A5000 Installation and Service Manual.
Figure A–2 shows a sample storage array configuration.
You must use FC switches when installing storage arrays in a partner-group configuration. If you want to create a storage area network (SAN) by using two FC switches and Sun SAN software, see SAN Solutions in a Sun Cluster Environment in Sun Cluster 3.1 - 3.2 Hardware Administration Manual for Solaris OS for more information.
For more information about how to cable and configure storage arrays, see the Sun StorEdge A5000 Configuration Guide and the Sun StorEdge A5000 Configuration Guide.
