Sun Cluster 3.1 - 3.2 With StorEdge A1000 Array, Netra st A1000 Array, or StorEdge A3500 System Manual
Adding a Sun StorEdge A3500 Storage System
Connect the differential SCSI cable between the node and the controller module, as shown in Figure A–4. Ensure that the entire SCSI bus length to each storage array is less than 25 m. This measurement includes the cables to both nodes, as well as the bus length that is internal to each storage array, node, and host adapter.
Figure A–4 Cabling a StorEdge A3500 Storage System: An Example, Part 1
Illustration: The preceding context describes the graphic.
Figure A–5 Cabling a StorEdge A3500 Storage System: An Example, Part 2
Illustration: Node B is connected to both controllers
in the storage system.
