This section contains the procedures listed in Table 2–1.
Table 2–1 Task Map: Installing Storage Arrays
Task |
Information |
Install a storage array in a new cluster, before the OS and Sun Cluster software are installed. | |
Add a storage array to an existing cluster. |
You can install your storage array in several different configurations: Figure 2–1 and Figure 2–2 are two examples.
Use this procedure to install a storage array in a new cluster. To add a storage array to an existing cluster, use the procedure in How to Add Storage Arrays to an Existing Cluster.
This procedure relies on the following assumptions:
You have not installed the Solaris Operating System.
You have not installed the Sun Cluster software.
Your cluster has not been established.
You have enough host adapters to connect the nodes and the storage array to the service processor panel.
If you need to install host adapters, see How to Replace a Host Adapter. When this procedure asks you to replace the failed host adapter, simply install the new host adapter instead.
Unpack, place, and level the storage array.
For instructions, see the Sun StorEdge 6130 Array Getting Started Guide. For a list of StorEdge documentation, see Table P–2.
(Optional) Install the Fibre Channel (FC) switch for the storage array if you do not have a switch installed.
For the procedure about how to install an FC switch, see the documentation that shipped with your FC switch hardware.
Connect the nodes to the service processor panel.
(SAN Configuration) Connect the FC switches to the service processor panel.
(Direct-Attached Configuration) Connect each node to the host ports on the array.
Install the storage array.
Power on the storage array and the nodes.
On all nodes, install the Solaris operating system and apply the required Solaris patches for Sun Cluster software and storage array support.
For the procedure about how to install the Solaris operating environment, see How to Install Solaris Software in Sun Cluster Software Installation Guide for Solaris OS.
If you are using Solaris OS software version 9, install any required patches or software for Solaris I/O multipathing software support to nodes and enable multipathing.
For the procedure about how to install the Solaris I/O multipathing software, see How to Install Sun Multipathing Software in Sun Cluster Software Installation Guide for Solaris OS.
To create a logical volume, see How to Create a Logical Volume.
To continue with Sun Cluster software installation tasks, see your Sun Cluster software installation documentation.
Use this procedure to add a new storage array to a running cluster. To install a new storage array in a Sun Cluster configuration that is not running, use the procedure in How to Install Storage Arrays in a New Cluster.
(Veritas Volume Manager Only) You have a version of Veritas Volume Manager that includes Array Support Library (ASL). For more information on this requirement, see Requirements.
You do not need to install a new node in your cluster.
If you need to add a node to your cluster, see your Sun Cluster system administration documentation. Ensure that you install the required Solaris patches for storage array support.
If you added a new node, perform the steps in Install the Solaris Operating System and Configure Multipathing as appropriate. Apply the correct patches for storage array support enable multipathing.
