This section contains the procedures about how to configure a storage system in a running cluster. Table 1–2 lists these procedures.
Table 1–2 Task Map: Configuring Storage Arrays|
Task |
Information |
Create a volume. | |
Remove a volume. |
The following is a list of administrative tasks that require no cluster-specific procedures. See the Sun StorEdge 6320 System Reference and Service Manual for the following procedures.
Use this procedure to create a logical volume from unassigned storage capacity.
Sun storage documentation uses the following terms:
Logical volume
Logical device
Logical unit number (LUN)
This manual uses logical volume to refer to all such logical constructs.
This procedure relies on the following prerequisites and assumptions.
All nodes are booted in cluster mode and attached to the storage device.
The storage device is installed and configured. If you are using multipathing, the storage device is configured as described in the installation procedure.
If you are using Solaris I/O multipathing (MPxIO) for the Solaris 10 OS, previously called Sun StorEdge Traffic Manager in the Solaris 9 OS, verify that it is installed and configured and the path to the storage device is functioning. To configure the Traffic Manager for the Solaris 9 OS, see the Sun StorEdge Traffic Manager Installation and Configuration Guide. To configure multipathing for the Solaris 10 OS, see the Solaris Fibre Channel Storage Configuration and Multipathing Support Guide.
This procedure provides the long forms of the Sun Cluster commands. Most commands also have short forms. Except for the forms of the command names, the commands are identical. For a list of the commands and their short forms, see Appendix A, Sun Cluster Object-Oriented Commands, in Sun Cluster 3.1 - 3.2 Hardware Administration Manual for Solaris OS.
Become superuser or assume a role that provides solaris.cluster.modify role-based access control (RBAC) authorization.
Follow the instructions in your storage device's documentation to create and map the logical volume. For a URL to this storage documentation, see Related Documentation.
Completely set up the logical volume. When you are finished, the volume must be created, mapped, mounted, and initialized.
If necessary, partition the volume.
To allow multiple clusters and nonclustered nodes to access the storage device, create initiator groups by using LUN masking.
If you are not using multipathing, skip to Step 5.
If you are using multipathing, and if any devices that are associated with the volume you created are at an unconfigured state, configure the multipathing paths on each node that is connected to the storage device.
To determine whether any devices that are associated with the volume you created are at an unconfigured state, use the following command.
# cfgadm -al | grep disk |
To configure the Solaris I/O multipathing paths on each node that is connected to the storage device, use the following command.
# cfgadm -o force_update -c configure controllerinstance |
On one node that is connected to the storage device, use the format command to label the new logical volume.
From any node in the cluster, update the global device namespace.
If you are using Sun Cluster 3.2, use the following command:
# cldevice populate |
If you are using Sun Cluster 3.1, use the following command:
# scgdevs |
You might have a volume management daemon such as vold running on your node, and have a DVD drive connected to the node. Under these conditions, a device busy error might be returned even if no disk is inserted in the drive. This error is expected behavior. You can safely ignore this error message.
To manage this volume with volume management software, use Solaris Volume Manager or Veritas Volume Manager commands to update the list of devices on all nodes that are attached to the new volume that you created.
For more information, see your Solaris Volume Manager or Veritas Volume Manager documentation.
To configure a logical volume as a quorum device, see Chapter 6, Administering Quorum, in Sun Cluster System Administration Guide for Solaris OS.
To create a new resource or configure a running resource to use the new logical volume, see Chapter 2, Administering Data Service Resources, in Sun Cluster Data Services Planning and Administration Guide for Solaris OS.
Use this procedure to remove a logical volume. This procedure defines Node A as the node with which you begin working.
Logical volume
Logical device
The logical volume and the path between the nodes and the storage device are both operational.
Become superuser or assume a role that provides solaris.cluster.read and solaris.cluster.modify RBAC authorization.
Identify the logical volume that you are removing.
Refer to your Solaris Volume Manager or Veritas Volume Manager documentation for more information.
(Optional) Migrate all data off the logical volume that you are removing. Alternatively, back up that data.
If the LUN that you are removing is configured as a quorum device, choose and configure another device as the quorum device. Then remove the old quorum device.
To determine whether the LUN is configured as a quorum device, use one of the following commands.
# clquorum show |
# scstat -q |
For procedures about how to add and remove quorum devices, see Chapter 6, Administering Quorum, in Sun Cluster System Administration Guide for Solaris OS.
If you are using volume management software, use that software to update the list of devices on all nodes that are attached to the logical volume that you are removing.
For instructions about how to update the list of devices, see your Solaris Volume Manager or Veritas Volume Manager documentation.
If you are using volume management software, run the appropriate Solaris Volume Manager or Veritas Volume Manager commands to remove the logical volume from any diskset or disk group.
Volumes that were managed by Veritas Volume Manager must be completely removed from Veritas Volume Manager control before you can delete them from the Sun Cluster environment. After you delete the volume from any disk group, use the following commands on both nodes to remove the volume from Veritas Volume Manager control.
# vxdisk offline Accessname # vxdisk rm Accessname |
Disk access name
If you are using multipathing, unconfigure the volume in Solaris I/O multipathing.
# cfgadm -o force_update -c unconfigure Logical_Volume |
Access the storage device and remove the logical volume.
To remove the volume, see your storage documentation. For a list of storage documentation, see Related Documentation.
Determine the resource groups and device groups that are running on all nodes.
Record this information because you use it in Step 14 and Step 15 of this procedure to return resource groups and device groups to these nodes.
Move all resource groups and device groups off Node A.
Shut down and reboot Node A.
To shut down and boot a node, see Chapter 3, Shutting Down and Booting a Cluster, in Sun Cluster System Administration Guide for Solaris OS.
On Node A, remove the paths to the logical volume that you removed. Remove obsolete device IDs.
For each additional node that is connected to the shared storage that hosted the logical volume, repeat Step 9 to Step 12.
(Optional) Restore the device groups to the original node.
Do the following for each device group that you want to return to the original node.
# cldevicegroup switch -n nodename devicegroup1[ devicegroup2 …] |
The node to which you are restoring device groups.
The device group or groups that you are restoring to the node.
# scswitch -z -D devicegroup -h nodename |
(Optional) Restore the resource groups to the original node.
Do the following for each resource group that you want to return to the original node.
# clresourcegroup switch -n nodename resourcegroup1[ resourcegroup2 …] |
For failover resource groups, the node to which the groups are returned. For scalable resource groups, the node list to which the groups are returned.
The resource group or groups that you are returning to the node or nodes.
# scswitch -z -g resourcegroup -h nodename |
