This section contains the procedure to verify that you installed and configured your data service properly.
Become superuser on one of the nodes in the cluster that hosts SWIFTAlliance Gateway.
Ensure that all the Sun Cluster resources are online.
# cluster status # clresource enable resource |
Move the Sun Cluster resource group to another cluster node, such as node1.
# clresource group switch -h node1 sag-rg |
Ensure that SWIFTAlliance Gateway stopped on node1 and that the application started on another node, such as node2.
When using a failover file system, the file system disappears on node1 and mounts on node2.
Go to Tuning the Sun Cluster HA for SWIFTAlliance Gateway Fault Monitor.
