Become superuser on one of the nodes in the cluster that hosts SWIFTAlliance Gateway.
Ensure that all the Sun Cluster resources are online.
# cluster status # clresource enable resource |
Move the Sun Cluster resource group to another cluster node, such as node1.
# clresource group switch -h node1 sag-rg |
Ensure that SWIFTAlliance Gateway stopped on node1 and that the application started on another node, such as node2.
When using a failover file system, the file system disappears on node1 and mounts on node2.
Go to Tuning the Sun Cluster HA for SWIFTAlliance Gateway Fault Monitor.
