This section describes the supported software and memory requirements for Sun Cluster 3.2 software.
Memory requirements – Sun Cluster 3.2 software requires the following memory requirements for every cluster node:
Minimum of 512 MB of physical RAM (2GB typical).
Minimum of 6GB of available hard drive space.
Actual physical memory and hard drive requirements are determined by the applications that are installed. Consult the application's documentation or contact the application vendor to calculate additional memory and hard drive requirements.
RSMAPI – Sun Cluster 3.2 software supports the Remote Shared Memory Application Programming Interface (RSMAPI) on RSM-capable interconnects, such as PCI-SCI.
Solaris Operating System (OS) – Sun Cluster 3.2 software and Quorum Server software requires the following minimum versions of the Solaris OS:
Solaris 9 – Solaris 9 9/05 SPARC only.
Solaris 10 – Solaris 10 11/06.
Solaris Trusted Extensions
Sun Cluster 3.2 supports Solaris non-global zones within a cluster. Solaris 10 11/06 includes support for Solaris Trusted Extensions. Solaris Trusted Extensions uses non-global zones as well. The interaction between Sun Cluster and Solaris Trusted Extensions using non-global zones has not been tested. Customers are advised to proceed with caution when using these technologies.
Volume managers
Platform |
Operating System |
Volume Manager |
Cluster Feature |
SPARC |
Solaris 9 |
Solaris Volume Manager. |
Solaris Volume Manager for Sun Cluster. |
VERITAS Volume Manager 4.1. This support requires VxVM 4.1 MP2. |
VERITAS Volume Manager 4.1 cluster feature. |
VERITAS Volume Manager components that are delivered as part of VERITAS Storage Foundation 4.1. This support requires VxVM 4.1 MP2. |
VERITAS Volume Manager components that are delivered as part of VERITAS Storage Foundation 5.0. This support requires VxVM 5.0 MP1. |
VERITAS Volume Manager 5.0 cluster feature. |
Solaris 10 |
VERITAS Volume Manager 4.1 with cluster feature. |
x86 |
Solaris 10 |
VERITAS Volume Manager components that are delivered as part of VERITAS Storage Foundation 4.1. |
N/A - Sun Cluster 3.2 does not support the VxVM cluster feature on the x86 platform. |
File systems
Sun StorEdgeTM Availability Suite 10
Sun Management Center 3.6.1
Data services (agents) – Contact your Sun sales representative for the complete list of supported data services and application versions.
Data service documentation, including man pages and wizard online help, is no longer translated to languages other than English.
The following Sun Cluster data services support non-global zones:
Sun Cluster Data Service for Apache
Sun Cluster Data Service for Apache Tomcat
Sun Cluster Data Service for DHCP
Sun Cluster Data Service for Domain Name Service (DNS)
Sun Cluster Data Service for Kerberos
Sun Cluster Data Service for mySQL
Sun Cluster Data Service for N1 Grid Service Provisioning Server
Sun Cluster Data Service for Oracle
Sun Cluster Data Service for Oracle Application Server
Sun Cluster HA for PostgreSQL
Sun Cluster Data Service for Samba
Sun Cluster Data Service for Sun Java System Application Server
Sun Cluster Data Service for Sun Java System Message Queue Server
Sun Cluster Data Service for Sun Java System Web Server
Procedures for the version of Sun Cluster HA for Sun JavaTM System Directory Server that uses Sun Java System Directory Server 5.0 and 5.1 are located in the Sun Cluster 3.1 Data Service for Sun ONE Directory Server. For later versions of Sun Java System Directory Server, see the Sun Java System Directory Server product documentation.
The following data services are not supported on Solaris 10 in this Sun Cluster release.
Sun Cluster Data Service for Agfa IMPAX
Sun Cluster Data Service for SWIFT Alliance Access
Sun Cluster Data Service for SWIFT Alliance Gateway
The following is a list of Sun Cluster data services and their resource types.
Data Service |
Sun Cluster Resource Type |
Sun Cluster HA for Agfa IMPAX |
SUNW.gds |
Sun Cluster HA for Apache |
SUNW.apache |
Sun Cluster HA for Apache Tomcat |
SUNW.gds |
Sun Cluster HA for BroadVision One-To-One Enterprise |
SUNW.bv |
Sun Cluster HA for DHCP |
SUNW.gds |
Sun Cluster HA for DNS |
SUNW.dns |
Sun Cluster HA for MySQL |
SUNW.gds |
Sun Cluster HA for NetBackup |
SUNW.netbackup_master |
Sun Cluster HA for NFS |
SUNW.nfs |
Sun Cluster Oracle Application Server |
SUNW.gds |
Sun Cluster HA for Oracle E-Business Suite |
SUNW.gds |
Sun Cluster HA for Oracle |
SUNW.oracle_server SUNW.oracle_listener |
Sun Cluster Support for Oracle Real Application Clusters |
SUNW.rac_framework SUNW.rac_udlm SUNW.rac_svm SUNW.rac_cvm SUNW.rac_hwraid SUNW.oracle_rac_server SUNW.oracle_listener SUNW.scaldevicegroup SUNW.scalmountpoint SUNW.crs_framework SUNW.scalable_rac_server_proxy |
Sun Cluster HA for PostgreSQL |
SUNW.gds |
Sun Cluster HA for Samba |
SUNW.gds |
Sun Cluster HA for SAP |
SUNW.sap_ci SUNW.sap_ci_v2 SUNW.sap_as SUNW.sap_as_v2 |
Sun Cluster HA for SAP liveCache |
SUNW.sap_livecache SUNW.sap_xserver |
Sun Cluster HA for SAP DB |
SUNW.sapdb SUNW.sap_xserver |
Sun Cluster HA for SAP Web Application Server |
SUNW.sapenq SUNW.saprepl SUNW.sapscs SUNW.sapwebas |
Sun Cluster HA for Siebel |
SUNW.sblgtwy SUNW.sblsrvr |
Sun Cluster HA for Solaris Containers |
SUNW.gds |
Sun Cluster HA for N1 Grid Engine |
SUNW.gds |
Sun Cluster HA for Sun Java System Application Server supported versions before 8.1 |
SUNW.s1as |
Sun Cluster HA for Sun Java System Application Server supported versions as of 8.1 |
SUNW.jsas SUNW.jsas-na |
Sun Cluster HA for Sun Java System Application Server EE (supporting HADB versions before 4.4) |
SUNW.hadb |
Sun Cluster HA for Sun Java System Application Server EE (supporting HADB versions as of 4.4) |
SUNW.hadb_ma |
Sun Cluster HA for Sun Java System Message Queue |
SUNW.s1mq |
Sun Cluster HA for Sun Java System Web Server |
SUNW.iws |
Sun Cluster HA for SWIFTAlliance Access |
SUNW.gds |
Sun Cluster HA for SWIFTAlliance Gateway |
SUNW.gds |
Sun Cluster HA for Sybase ASE |
SUNW.sybase |
Sun Cluster HA for WebLogic Server |
SUNW.wls |
Sun Cluster HA for WebSphere MQ |
SUNW.gds |
Sun Cluster HA for WebSphere MQ Integrator |
SUNW.gds |
Sun Cluster Security Hardening uses the Solaris operating system hardening techniques recommended by the Sun BluePrintsTM program to achieve basic security hardening for clusters. The Solaris Security Toolkit automates the implementation of Sun Cluster Security Hardening.
The Sun Cluster Security Hardening documentation is available at http://www.sun.com/blueprints/0203/817-1079.pdf. You can also access the article from http://www.sun.com/software/security/blueprints. From this URL, scroll down to the Architecture heading to locate the article “Securing the Sun Cluster 3.x Software.” The documentation describes how to secure Sun Cluster 3.x deployments in a Solaris environment. The description includes the use of the Solaris Security Toolkit and other best-practice security techniques recommended by Sun security experts. The following data services are support by Sun Cluster security hardening:
Sun Cluster HA for BEA WebLogic Server
Sun Cluster HA for N1 GridEngine
Sun Cluster HA for Sun Java System Directory Server
Sun Cluster HA for Sun Java System Messaging Server
