Figure 3–3 assumes you are running mission-critical applications (Oracle database, for example) on Node A and Node B. If Node A and Node B are unavailable and cannot access shared data, you might want the entire cluster to be down. Otherwise, this configuration is suboptimal because it does not provide high availability.
For information about the best practice to which this exception relates, see Adhering to Quorum Device Best Practices.
