Sun Cluster Data Service for SAP Guide for Solaris OS
Preface
Sun Cluster Data Service for SAP Guide for Solaris OS explains how to install and configure SunTM Cluster HA for SAP on both SPARC® based systems and x86 based systems.
Note –
This Sun Cluster release supports systems that use the SPARCTM and x86 families of processor architectures: UltraSPARC, SPARC64, and AMD64. In this document, the label x86 refers to systems that use the AMD64 family of processor architectures.
This document is intended for system administrators with extensive knowledge of Sun software and hardware. Do not use this document as a planning or presales guide. Before reading this document, you should have already determined your system requirements and purchased the appropriate equipment and software.
The instructions in this book assume knowledge of the SolarisTM Operating System (Solaris OS) and expertise with the volume-manager software that is used with Sun Cluster software.
Note –
Sun Cluster software runs on two platforms, SPARC and x86. The information in this document pertains to both platforms unless otherwise specified in a special chapter, section, note, bulleted item, figure, table, or example.
Using UNIX Commands
This document contains information about commands that are specific to installing and configuring Sun Cluster data services. The document does not contain comprehensive information about basic UNIX® commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P–1 Typographic Conventions
Typeface
Meaning
Example
AaBbCc123
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
What you type, contrasted with onscreen computer output
machine_name% su
Password:
aabbcc123
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
AaBbCc123
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows the default UNIX system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
Shell
Prompt
C shell
machine_name%
C shell for superuser
machine_name#
Bourne shell and Korn shell
Bourne shell and Korn shell for superuser
Related Documentation
Information about related Sun Cluster topics is available in the documentation that is listed in the following table. All Sun Cluster documentation is available at http://docs.sun.com.
Topic
Documentation
Data service administration
Sun Cluster Data Services Planning and Administration Guide for Solaris OS
Individual data service guides
Concepts
Sun Cluster Concepts Guide for Solaris OS
Overview
Sun Cluster Overview for Solaris OS
Software installation
Sun Cluster Software Installation Guide for Solaris OS
System administration
Sun Cluster System Administration Guide for Solaris OS
Hardware administration
Sun Cluster 3.1 - 3.2 Hardware Administration Manual for Solaris OS
Individual hardware administration guides
Data service development
Sun Cluster Data Services Developer’s Guide for Solaris OS
Error messages
Sun Cluster Error Messages Guide for Solaris OS
Command and function reference
Sun Cluster Reference Manual for Solaris OS
For a complete list of Sun Cluster documentation, see the release notes for your release of Sun Cluster at http://docs.sun.com.
Related Third-Party Web Site References
Third-party URLs that are referenced in this document provide additional related information.
Note –
Sun is not responsible for the availability of third-party web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Sun will not be responsible or liable for any actual or alleged damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
Documentation, Support, and Training
The Sun web site provides information about the following additional resources:
Getting Help
If you have problems installing or using Sun Cluster, contact your service provider and provide the following information:
Use the following commands to gather information about each node on your system for your service provider.
Command
Function
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
showrev –p
Reports which patches are installed
prtdiag -v
Displays system diagnostic information
/usr/cluster/bin/clnode show-rev
Displays Sun Cluster release and package version information
Also have available the contents of the /var/adm/messages file.
