Sun Cluster Data Services Developer's Guide for Solaris OS
Cluster Functions
These functions access or return information about a cluster.
scha_cluster_open(), scha_cluster_get(), and scha_cluster_close()
These functions access information about a cluster, such as the cluster name, node name, zone name, IDs, states, and resource groups.
A cluster can change, through reconfiguration or administrative action, after scha_cluster_open() returns the cluster's handle. As a result, the information that scha_cluster_get() obtains through the handle might be inaccurate. In cases of reconfiguration or administrative action on a cluster, the RGM returns the scha_err_seqid error code to scha_cluster_get() to indicate that information about the cluster might have changed. This error message is non-fatal. The function returns successfully. You can choose to ignore the message and accept the returned information. Alternatively, you can close the current handle and open a new handle to access information about the cluster.
One man page describes these three functions. You can access this man page through any of the individual functions scha_cluster_open(3HA), scha_cluster_get(3HA), and scha_cluster_close(3HA).
scha_cluster_getlogfacility()
Returns the number of the system log facility that is being used as the cluster log. Uses the returned value with the syslog() Solaris function to record events and status messages to the cluster log. This function is described in more detail in the scha_cluster_getlogfacility(3HA) man page.
scha_cluster_getnodename()
Returns the name of the cluster node on which the function is called. This function is described in more detail in the scha_cluster_getnodename(3HA) man page.
