Sun Cluster Data Services Developer's Guide for Solaris OS
RMAPI Resource Commands
You can access information about a resource or set the Status and Status_msg properties of a resource with these commands.
scha_resource_get
Accesses information about a resource or resource type that is under the control of the RGM. This command provides the same information as the scha_resource_get() C function. For details, see the scha_resource_get(1HA) man page.
scha_resource_setstatus
Sets the Status and Status_msg properties of a resource that is under the control of the RGM. This command is used by the resource's monitor to indicate the state of the resource as perceived by the monitor. This command provides the same functionality as the scha_resource_setstatus() C function. This command is described in more detail in the scha_resource_setstatus(1HA) man page.
Note –
Although scha_resource_setstatus() is of particular use to a resource monitor, any program can call it.
