NAME | Synopsis | Description | Parameters | Files | Attributes | See Also
cc [flags…] -I /usr/cluster/include file -L /usr/cluster/lib -l dsdev #include <rgm/libdsdev.h> void scds_fm_print_probes(scds_handle_t handle, int debug_level);
The scds_fm_print_probes() function writes probe status information, reported with scds_fm_action(3HA), to the system log. This information includes a list of all probe status history maintained by the DSDL and the timestamp associated with the probe status.
The DSDL defines the maximum debugging level, SCDS_MAX_DEBUG_LEVEL, as 9.
If you specify a debug_level greater than the current debugging level being used, no information is written.
The following parameters are supported:
The handle returned from scds_initialize(3HA).
Debugging level at which the data is to be written. It is an integer between 1 and SCDS_MAX_DEBUG_LEVEL, defined as 9 by the DSDL.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWscdev |
Interface Stability |
Evolving |
