Name | Synopsis | Description | Parameters | Return Values | Errors | Files | Attributes | See Also
cc [flags…] -I /usr/cluster/include file -L /usr/cluster/lib -l dsdev #include <rgm/libdsdev.h> scha_err_t scds_pmf_signal(scds_handle_t handle, scds_pmf_type_t program_type, int instance, int signal, time_t timeout);
The scds_pmf_signal() function sends the specified signal to a process tree running under PMF control. This function is equivalent to the pmfadm(1M) command with the -k option.
After sending the signal, the scds_pmf_signal() function waits for the specified timeout period for the process tree to die, before returning. A value of 0 for timeout tells the function to return immediately without waiting for any process to exit. A value of -1 tells the function to wait indefinitely for the processes to exit.
The following parameters are supported:
The handle returned from scds_initialize()
Type of program to execute. Valid types are:
Data service application
Fault monitor
Other
For resources with multiple instances, this integer, starting at 0, uniquely identifies the instance. For single instance resources, use 0.
Solaris signal to send. See signal(3HEAD).
Timeout period in seconds.
The scds_pmf_signal() function returns the following:
The function succeeded.
The function failed.
The process tree did not exit within the specified timeout period after the signal was sent.
Indicate the function failed. See scha_calls(3HA) for the meaning of failure codes.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWscdev |
Interface Stability |
Evolving |
