Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
delete-connector-connection-pool [--help] [--target target]
[--cascade={false|true}] poolname
The delete-connector-connection-pool subcommand removes the specified connector connection pool.
This subcommand is supported in remote mode only.
Displays the help text for the subcommand.
Do not specify this option. This option is retained for compatibility with other releases. If you specify this option, a syntax error does not occur. Instead, the subcommand runs successfully and the option is silently ignored.
When set to true, all connector resources associated with the pool, and the pool itself, are deleted. When set to false, the deletion of pool fails if any resources are associated with the pool. The resource must be deleted explicitly or the option must be set to true. Default is false.
This example deletes the connector connection pool named jms/qConnPool.
asadmin> delete-connector-connection-pool --cascade=false jms/qConnPool Command delete-connector-connection-pool executed successfully |
