Sun Java System Directory Server Enterprise Edition 6.1 Administration Guide
Configuring Directory Proxy Server for Distribution of Suffix Data
A simple case of data distribution consists of storing entries having UIDs beginning with A through M in one set of directories, and storing entries having UIDs beginning with N through Z in another set of directories. Directory Proxy Server receives all client operations. The server must determine which set of directories handles A through M, and which set handles N through Z.
    The key stages in configuring Directory Proxy Server to handle this data distributions scenario are as follows.
  1. Add directories as data sources for Directory Proxy Server.
  2. Add the data sources to data source pools to handle the different data distributions.
  3. Create data views designed to distribute client requests to the appropriate data pools.
  4. Split the LDIF to be loaded into the appropriate data sources.
  5. Import the split LDIF into the appropriate data sources.
  6. Adjust the operation based weights for the data sources attached to the appropriate data pools.
The following example involves Directory Proxy Server, listening on port 9389. To keep the example simple, the proxy is configured here to distribute as described across only three Directory Server instances. For availability and read scalability, use replicated directory topologies to store LDAP data. One Directory Server instance, dsA-M:1389 handles the user entries having UIDs beginning with A through M. Another Directory Server instance, dsN-Z:2389, handles the user entries having UIDs beginning with N through Z. A final directory instance handles the base entries of the suffix, dsBase:3389.
The first step creates and enables the data sources. The base data source holds entries near the root of the suffix that do not have UIDs. In a typical deployment, these entries would be much fewer in number than distributed entries.
$ dpconf create-ldap-data-source -p 9389 dsA-M localhost:1389
$ dpconf set-ldap-data-source-prop -p 9389 dsA-M is-enabled:true
$ dpconf create-ldap-data-source -p 9389 dsN-Z localhost:2389
$ dpconf set-ldap-data-source-prop -p 9389 dsN-Z is-enabled:true
$ dpconf create-ldap-data-source -p 9389 dsBase localhost:3389
$ dpconf set-ldap-data-source-prop -p 9389 dsBase is-enabled:true
The second step adds the data sources to a data source pool.
$ dpconf create-ldap-data-source-pool -p 9389 "Base Pool"
$ dpconf attach-ldap-data-source -p 9389 "Base Pool" dsBase
$ dpconf create-ldap-data-source-pool -p 9389 "A-M Pool"
$ dpconf attach-ldap-data-source -p 9389 "A-M Pool" dsA-M
$ dpconf create-ldap-data-source-pool -p 9389 "N-Z Pool"
$ dpconf attach-ldap-data-source -p 9389 "N-Z Pool" dsN-Z
The third step creates data views designed to distribute client requests to the appropriate data pools. Notice how the base pool handles dc=example,dc=com, whereas the pools holding data distributed according to UID values handle ou=people,dc=example,dc=com. This step requires a server restart.
$ dpconf create-ldap-data-view -p 9389 "Base View" "Base Pool" \
dc=example,dc=com
$ dpconf create-ldap-data-view -p 9389 "A-M View" "A-M Pool" \
$ dpconf set-ldap-data-view-prop -p 9389 "A-M View" \
distribution-algorithm:lexicographic lexicographic-attrs:uid \
lexicographic-lower-bound:a lexicographic-upper-bound:m
The proxy server will need to be restarted in order for the changes to take effect
$ dpconf create-ldap-data-view -p 9389 "N-Z View" "N-Z Pool" \
$ dpconf set-ldap-data-view-prop -p 9389 "N-Z View" \
lexicographic-lower-bound:n lexicographic-upper-bound:z
$ dpadm restart /local/dps
The fourth step splits the LDIF to be loaded into the appropriate data sources. This example uses both the dsadm split-ldif command to perform the initial split, and also some file editing to retain the top entry in all the data sources. This makes it possible both to retain the top entry that specifies access control instructions, and to use a single import command for each data source.
$ dpadm split-ldif /local/dps /local/ds6/ldif/Example.ldif /tmp/
[14/May/2007:21:14:13 +0200] - STARTUP    - INFO  - Java Version: 1.5.0_09
 (Java Home: /local/jre)
[14/May/2007:21:14:13 +0200] - STARTUP    - INFO  - Java Heap Space: Total Memory
 (-Xms) = 3MB,
 Max Memory (-Xmx) = 63MB
[14/May/2007:21:14:13 +0200] - STARTUP    - INFO  - Operating System: SunOS/sparc 5.10
[14/May/2007:21:14:15 +0200] - INTERNAL   - ERROR - Entry starting at line 0 does not
 start with a DN
[14/May/2007:21:14:15 +0200] - INTERNAL   - ERROR - Unable to parse line "# Kirsten is
 a Directory Administrator and therefore should not" of entry "uid=kvaughan, ou=People,
 dc=example,dc=com" starting at line 112 as an attribute/value pair -- no colon found.
[14/May/2007:21:14:15 +0200] - INTERNAL   - ERROR - Unable to parse line "# Robert is
 a Directory Administrator and therefore should not" of entry "uid=rdaugherty,
 ou=People, dc=example,dc=com" starting at line 298 as an attribute/value pair --
 no colon found.
[14/May/2007:21:14:16 +0200] - INTERNAL   - ERROR - Unable to parse line "# Harry is
 a Directory Administrator and therefore should not" of entry "uid=hmiller, ou=People,
 dc=example,dc=com" starting at line 556 as an attribute/value pair -- no colon found.
[14/May/2007:21:14:16 +0200] - INTERNAL   - INFO  - SplitLDIF processing complete.
  Processed 156 entries.
$ ls /tmp/*ldif
/tmp/a-m view.ldif    /tmp/base view.ldif   /tmp/n-z view.ldif
This step also requires a top entry that is added to the LDIF before import.
$ cp /local/ds6/ldif/Example.ldif /tmp/top.ldif
$ vi /tmp/top.ldif
$ cat /tmp/top.ldif
dn: dc=example,dc=com
objectclass: top
objectclass: domain
dc: example
aci: (target ="ldap:///dc=example,dc=com")(targetattr !=
 "userPassword")(version 3.0;acl "Anonymous read-search access";
 allow (read, search, compare)(userdn = "ldap:///anyone");)
aci: (target="ldap:///dc=example,dc=com") (targetattr =
  "*")(version 3.0; acl "allow all Admin group"; allow(all) groupdn =
  "ldap:///cn=Directory Administrators,ou=Groups,dc=example,dc=com";)
$ cat /tmp/top.ldif /tmp/base\ view.ldif > /tmp/top\ and\ base\ view.ldif
$ cat /tmp/top.ldif /tmp/a-m\ view.ldif > /tmp/top\ and\ a-m\ view.ldif
$ cat /tmp/top.ldif /tmp/n-z\ view.ldif > /tmp/top\ and\ n-z\ view.ldif
The fifth step imports the split LDIF into the appropriate data sources. Here, the directory handling the base entries is on port 3389. The directory handling A-M is listening on port 1389. The directory handling N-Z is listening on port 2389.
$ dsconf import -p 1389 /tmp/top\ and\ a-m\ view.ldif dc=example,dc=com
Task completed (slapd exit code: 0).
$ dsconf import -p 2389 /tmp/top\ and\ n-z\ view.ldif dc=example,dc=com
$ dsconf import -p 3389 /tmp/top\ and\ base\ view.ldif dc=example,dc=com
The sixth step adjusts the operation based weights for the data sources attached to the appropriate data pools. If client applications perform operations other than searches, then weights must be set for those operations as well.
$ dpconf set-attached-ldap-data-source-prop -p 9389 "Base Pool" dsBase search-weight:1
$ dpconf set-attached-ldap-data-source-prop -p 9389 "A-M Pool" dsA-M search-weight:1
$ dpconf set-attached-ldap-data-source-prop -p 9389 "N-Z Pool" dsN-Z search-weight:1
After the operations based weights are set, client applications can search through Directory Proxy Server as if the data were not physically distributed.
The following search looks for a user whose UID begins with R.
$ ldapsearch -p 9389 -b dc=example,dc=com uid=rfisher
version: 1
dn: uid=rfisher, ou=People, dc=example,dc=com
cn: Randy Fisher
sn: Fisher
givenName: Randy
objectClass: top
objectClass: person
objectClass: organizationalPerson
objectClass: inetOrgPerson
ou: Human Resources
ou: People
l: Cupertino
uid: rfisher
mail: rfisher@example.com
telephoneNumber: +1 408 555 1506
facsimileTelephoneNumber: +1 408 555 1992
roomNumber: 1579
The next search looks for one of the base entries.
$ ldapsearch -p 9389 -b ou=groups,dc=example,dc=com cn=hr\ managers
version: 1
dn: cn=HR Managers,ou=groups,dc=example,dc=com
objectClass: top
objectClass: groupOfUniqueNames
cn: HR Managers
ou: groups
uniqueMember: uid=kvaughan, ou=People, dc=example,dc=com
uniqueMember: uid=cschmith, ou=People, dc=example,dc=com
description: People who can manage HR entries
